Previous in Forum: Boiler Burner Calculation   Next in Forum: Definition Requalification
Calculation of Torque
02/07/2008 4:59 AM
How to find out the torque to rotate a central driven clarifier mechanism having a weight of 1000 kg. This mechanism is under the water. Size of the tank is dia 20 meter x 4.5 m Standard Water Depth.
Re: Calculation of Torque
02/07/2008 5:50 AM
How fast is is going? What is the cross-sectional area of the scrapers? How many blades are there?
02/08/2008 3:41 AM
I just reengineered one with Diameter 30 m,Maxwater depth 6metre at speed 6 minutes/revolution. I usd a 5HP motor+planetary gear drive-all Indian--+Chain to wheels.
It is running quietly at 40% rated (inferred from Current and cosØ) torque.
The central Bearing-I changed over to Spherical Self-aligning roller SKF---22 size.
And retained the old forbished bronze plate dia 3' bearing as last standby with 8mm gap i.e. not normally rubbing.
