Yes, we have been here before on this subject. Some new things have come to light however.
I have filed for pat. pending on the fallowing theory for pre spinning wheels before landing ( 50 yr old problem).
Sequence of operation:
- Deploy wheels into air stream
- Inject HP air between brake pads and rotors to release friction of pads.
- Start wheel rotation via a fixed Pelton wheel hub cap or combination.
- Maintain in flight 50 degree (F) lube oil temp, via a seal by-pass,two pipe system. (changes from standard greased bearings) Use of small lube oil pump and small electric heaters.
Advantage, Huge savings in maintenance cost of tire and bearings and general maintenance.
What do you think?
