Previous in Forum: Distribution problems.   Next in Forum: Motor Requirements
Light
02/18/2008 11:38 PM
Is there any softwere avilable for calculating illumination level.
Re: Light
02/19/2008 12:02 AM
lux can be measured by gauge.
it inverse proportion to distance2.
this can be calculated by calculator easily.
Re: Light
02/20/2008 1:59 AM
Try to use CalculuX Indoor 5.0 by Philips Lightings
Good Answers: 230
Re: Light
02/19/2008 1:16 AM
Hello pranayshah
Try FLUCS from here: http://www.eere.energy.gov/buildings/tools_directory/software.cfm/ID=275/pagename=alpha_list
Design mode calculates, using the UK CIBSE design method, the optimum number and spacing of identical luminaires in a rectangular array to provide the required illumination levels on the working surface and to meet the maximum glare requirement. Analysis mode calculates the actual illumination levels due to any number of luminaires of any type, taking into account the reflections from walls, ceiling, floor and partitions. Illumination levels due to daylight through windows can also be calculated separately or combined with the artificial lighting. It includes a large database of manufacturers' luminaires and lamps. This database is editable and data may be imported/exported in CIBSE or IES (North America) format.
You normally don't need a Software Program, have a look at my earlier Post here: http://cr4.globalspec.com/comment/184488/Re-lux-cal
Hope that helps you.
Kind Regards....
Re: Light
02/21/2008 2:49 AM
There are may software available in net or with lighting product manufacturer. Contact them.
BNDas
Register to Reply 4 comments
biswanath.das (1); cnpower (1); Sparkstation (1); superman27532003 (1)
