Previous in Forum: Powerfactor Improvement   Next in Forum: Purpose of Parallel Transformers - example
HOW TO SELECT CU & DF
02/23/2008 7:12 AM
HOW TO CALCULATE LUX FOR THE ARE GIVEN BELLO.AND HOW TO SELECT CU & BU
AREA=25M X15M
Re: HOW TO SELECT CU & DF
02/23/2008 11:23 AM
How to understand what the heck you are asking?
02/24/2008 11:28 PM
Incomplete information. Is it direct/indirect? height? etc...
"I know less than all, but more than many who know less"
02/25/2008 12:31 PM
LUX is ok Bello is may be below what is CU and DF cu is current?BU I give up
02/25/2008 11:35 PM
FOR YOUR INFO.
CU = Coefficient of Utilization - Ratio of the lumens actually received by a particular surface to the total lumens emitted by the luminous source. This is dependent on the type of lamp, type of lighting system and color of the room.
DF= Depreciation Factor - It is the factor related cleanliness of the lamp including the room , replacement od lamp after recommended life, etc.
CU = lumens received/lumens emitted by lightsource
DF = illumination when everything is new/illumination under actual condition
02/26/2008 5:31 AM
http://www.google.co.uk/search?sourceid=navclient-menuext&ie=UTF-8&q=BELLO
Please turn off Caps Lock and define 'bello' for the benefit of the confused reader.
Good Answers: 230
02/26/2008 9:50 PM
Hello PWSlack
In lieu of the Topic Starter's explanation:
  1. Bello is the first name often used in Africa for a boy.
  2. BELLO may be a shortened version of BELLOW - Which is done by using all CAPITALS in a Post on a Forum.
  3. BELLO may be a mis-spelled version of "Below".
I can understand the confusion, because I was konfuzed myself, not being a mind-reader either.
Trust that assists.
Kind Regards....
adhyartha (1); Anonymous Poster (1); nesubra (1); PWSlack (1); Sparkstation (1); superman27532003 (1)
