I have a 97 Taurus which has the PO715 code showing. The car shifts normally for about 20 to 30 minutes of driving then after that the transmission "bangs" into second gear when accelerating from a full stop or slow speed. There are also 3 other codes showing. PO102-MAF sensor circuit low input. PO171-System Adaptive Fuel too lean (Bank 1). PO174-System Adaptive Fuel too lean (Bank 2). The engine is a 3.0L, 182-cid, OHV V6. It has 131,000 miles on it. The check engine light has never come on. I know the MAF is not too expensive to replace but what about the Input/Turbine Speed Sensor?? I was planning on selling the car before all this and need to know if the Tranny problem will be an expensive fix. Depending on how expensive the fix is will determine what I will ask for the car. I want to be up front with whomever may buy it. Other than these problems the car has been really reliable. Any input you can give me will be helpful.
Thanks,
Mitch
