Previous in Forum: Connecting Capacitor Bank to 3-Phase (440 volt) Motor   Next in Forum: Motor Problems
Electric Condensation of Water
03/04/2008 4:26 AM
Hi All
When moist air is passed through a cold coil then moisture of the air is removed
due to condensation of water .Another method may be to pass the moist air
through a suitable electric field so that water molecules would begin to allign
and hence facilitates condensation of water from moist air .
Ashraf
Pathfinder Tags: condensation
Re: electric condensation of water
03/04/2008 4:49 AM
Quite how an electric field is supposed to dehumidify is currently obscure. It's fine trying it, until the field strength is so strong that a spark develops and the field breaks down.
Wise money is on the cooling technique. It's a safe bet.
03/05/2008 12:04 AM
Hi PWSlack
Of course I will try this technique to study the effect of electric filed on condensation
of water from moist air .I think we should experiment on different temperatures upto
100 C ! .I think the same theory may be applied on the raining .
Good Answers: 230
03/04/2008 4:51 AM
Hello AshrafSiddiqui
Thank you for your advice.
<"Another method may be to pass the moist air
and hence facilitates condensation of water from moist air .">
Of course the moisture in the air would need to actually condense onto a cooler surface.
Kind Regards....
Good Answers: 804
Re: Electric Condensation of Water
03/05/2008 12:09 AM
Actually, he is sort of describing a Wet Electro Static Precipitator (WESP), used more for removing particulates rather than the moisture, but it essentially does remove the moisture too.
You can also affect this kind of action with electricity by using a peltier device to create the cold surface.
Good Answers: 230
03/05/2008 3:39 AM
Hello JRaef
Thank you for the WESP information.
Re the "Peltier" device, I used "Frigistors" back in the early 1960'sfrom the De La Rue Frigistor Co, based in the UK, and very effective they were too, for removing excess heat from early germanium power transistor heatsinks.
Electricity can also be more commonly used to make a cooler surface for condensation of water vapour, via the compressor/evaporator system (refrigeration), as the technology is well proven.
Kind Regards....
Good Answers: 59
03/05/2008 5:02 PM
Look up the "Wilson Chamber".
Good Answers: 230
03/05/2008 7:21 PM
Hello leveles
I took your advice.
Drops of water fell into my eyes.
Kind Regards....
Register to Reply 7 comments
AshrafSiddiqui (1); JRaef (1); leveles (1); PWSlack (1); Sparkstation (3)
