am attempting to make a 1 rev/day drive for my 12 inch astronomical telescope. The drive needs to be continouous and constant velocity if the stars are to remain fixed in the field of view. I dont want to see the stars move backwards and forward as teeth of the gearing chain mesh and unmesh
The final drive is a harmonic drive (200:1) from an old linear accelerator. Because it works by distorting an inner gear (teeth on the outside of a thin walled tube by an inner rubbing elliptical cam) to mesh with the teeth on the inside of larger cylindrical drive, that there are many teeth meshing simultaneously which should produce a smooth constant velocity action. Can anyone with experience of such drives confirm this?
I wish to drive the harmonic drive with a worm drive. I intend to make a worm and worm wheel to give me a high ratio (eg ~200:1) by cutting the teeth into a circular piece of polythene (about 150 mm diameter and 16mm thick) using a threaded rod with flutes ground into it (like a tap). I would then use a fresh piece of threaded rod for the worm. I do not have access to a lathe to cut my own worm, and envisage using a piece of accurately machined "all- thread" of say 12-15 mm diameter and ~2mm pitch.
If I make the worm run in close contact to the wheel, I expect that the worm will contact the wheel continuously, so the action should be smoothe, but will it be constant velocity??
Is the thread form of the worm critical to having the worm and wheel work smoothly and constant velocity. Would an AJAX threaded bar make a better worm thread form than Whiworth or UNC?
