Previous in Forum: Water in crude oil   Next in Forum: kinematic viscosity
Compensating cable Problem
03/15/2008 3:27 AM
Ours is a Glass fibre plant and we have 32 nos of bushings ( From where molten glass is drawn in the form of fibres and wound on bobbins)The bushing temperature is sensed using 'R' type T/C's.The T/c length is 0.5 metre.This is then connected to a PID controller UT321( Yokogawa make )via 'R' type compensating cable situated at a distance of 25 metres in a control room with a contol ambient temperatute of 26 deg +/- 4 deg cent.The controller setpoint is 1100 deg cent.Now the problem is that whenever the bushing stops i.e when the fibres are not drawn the temperatute surrounding the T/C & compensating cable increases to around 70 to 80 deg since the bushing temperature increases and it goes on incrreasing leading to a thermal runnaway situation.The pid controller however shows a steady temperature of 1100 deg cent ( which is the controller setpoint ).It is also noted that the PID controller o/p goes on increasing and the bushing becomes very hot.The operator then has to put the controller in manual and decrease the temperature of the bushing to bring the temperature to normal.Our accesement is that the compensating cable is not able to compensate for the increase in temperature surrounding the junction and ends up giving wrong mv ( less then actual ) to the controller which in turn takes action to maintain the temperature by increasing the output leading to thermal runnaway of the bushing.We have tried thermally insulating the junction and it works which proves that our accessment is right but we feel that the issue is of compensating cable temperature limits.Is there any restriction on the max junction temperature up to which the compensating cable can work.Pls give ur valuable comments and help us solve our problem.
Good Answers: 54
Re: Compensating cable Problem
03/15/2008 4:17 AM
There are conflicting statements in your posts which makes it difficult to understand.
  1. You control the temperature of your bushings - I expected this is done by cooling but you mention that your controller output is increasing when the temperature of the bushing is increasing also, making it hotter?
  2. You mention that you are using type R thermocouples and type R extension cables (which is the correct thing to do). Yet you say that your thermocouple-extension cable junction is affected by temperature (which shouldn't be).
I think you left out some important details in your post in an attempt to make it shorter.
Try adding a simple drawing of your application so that we can get a better picture (pun unintended) of your problem.
03/24/2008 5:33 PM
I think you should be sure that the cable is a compensating cable nt an extension cable . IS this cable a sintered teflon cable with braidings ,,,
check and than we will find out a solution
03/24/2008 5:38 PM
hey man soory
is this cable directly to the UT321 or 4-20 ma through transmitter
03/25/2008 1:04 AM
The 'R' Type compensating cable is terminated on the other side to a transmitter situated at @ 10 metres from the t/c joint and then 4-20 ma is transmitted to ut321 at @25 metres.
Register to Reply 4 comments
