Previous in Forum: Chrome finish for abrasion resistance   Next in Forum: PC up dates
34 comments
Popular Science - Weaponology - New Member Popular Science - Cosmology - New Member Safety - Hazmat - New Member
Creative Brainstorming for a Stressed Planet
03/24/2008 4:05 PM
The following bit of somewhat disjointed and unrefined thought flow is presented for critical review of all my enlightened associates' commentary.
  1. Problem 1: serious water shortage foreseen for the Colorado River drainage, entailing dramatic consequences for major metro. areas of the SW, including Phoenix, Los Angeles, San Diego, Tucson, etc.; and curtailment of agriculture throughout the area.
  2. Problem 2: Marginal electric capacity sufficient to meet "peak demands" in the above areas, as well as Northern California.
  3. Problem 3: After 2 decades of (unwise) suppression of nuclear power generation,several applications for siting have recently been received. One of the environmental negative consequences of nuclear power is the disposition of the hot cooling water, either thru remote discharge, or the construction of elaborate cooling towers.
Proposed brain "storm"
The Nuclear power plants should be used to power enormous pumping stations which push water to large clay-lined reservoirs atop the Sierra. The water so pushed should include the cooling water, thus eliminating problem # 3 above.
The stored warm/hot water will be released through hydroelectric generators as required down the Eastern slope of the Sierras as required to meet peak electric demand in the service area, thus addressing problem # 2 above.
The still highly pressurized water will be released thru spray nozzles at appropriate locations, resulting in significant evaporation (and cooling):
the water will be discharged in areas formally occupied by the remnants of the inland ocean which until recently (geologically) filled the entirety of the Great Basin.
Such areas are typically already highly saline with various metallic salts, and would likely sustain no damage from the additional evaporative residue.
Over a few dozen years, large shallow saline lakes would accrue, whose evaporative surface at the typical 110F summer day in Nevada would produce huge amounts of water vapor to be carried East by prevailing winds to precipitate in the drainages of the Colorado, Rio Grande, and other areas.
Cloud formation could be anticipated to at least balance out the heat-retention greenhouse effect of water vapor.
Thus, problem 3 is addressed.
Q. E. D.
NOT "Querulous Erectile Dysfunction)
Re: Creative Brainstorming for a Stressed Planet
03/24/2008 5:29 PM
Where do you get this proposed water from? Bearing in mind poit 1 of your post?
03/24/2008 6:09 PM
Where do you get this proposed water from? Bearing in mind point 1 of your post?
there's a fine example of a mindset conditioning a communication.
Doesn't everybody know I am, (to be Specific), near the Pacific??? I do!
I jest at my own error. The water would be sucked from the Pacific ocean, or so I propose.
My bad.
03/24/2008 7:01 PM
So, you'd end up with a salt water river?..not great for the environment....
03/24/2008 8:50 PM
Del! DUDE! I must insist you read the post.
Particularly the part about the salt water being deposited ??wHeRe??
In for example places like the Great Salt Lake, comma, the vestiges of the GREAT BASIN water which has NO external outlet and whose many playas are characterized by ALREADY being METALLIC SALT SATURATED!!
Look up "Great Basin", or "Salt Lake"..
03/25/2008 3:28 AM
Whoops sorry.. para #4 was waaaaay past my attention span....
<slinks off monitor left, dragging tail...>
03/25/2008 10:14 AM
Here Del, I'm afraid the time has come!!!!!
Sorry about that Del.
Good Answers: 66
03/24/2008 7:01 PM
If I understand correctly, you are proposing to pump sea-level cooling water from a nuclear power plant to holding ponds in the Sierras. I took a look at some rough numbers; check my math:
A 700MW coal-fired power plant needs about 100,000 m3/hr of once-through cooling water (I presume a similar sized nuke plant will require a similar amount of water). Thats 27,778 kg/s of water (I know, salt water is lighter, but rough numbers here) pumped to an approximate elevation of 2000 m requiring 545MW (ignoring any losses). So, 78% of the plant's output goes solely to pumping the water to the holding pond. That seems like a tremendous amount of effort; assuming you could ever write an environmental impact statement that would satisfy California, Nevada, the DOE and the EPA. I know you'll get some of the power back from the hydro plants on the east side, but the losses will be significant.
It is a very intriguing and ambitious plan (partially terra-forming the planet, no less!) but I wonder about it's practical application. Not to mention what unintended consequences to weather patterns could result.
Aequam memento rebus in arduis servare mentem.
03/24/2008 8:56 PM
Thanks for the calculations, I thought I was gonna have to do it myself!
Like how many KW per gallon, or something I'd have to dredge up out of an old book.
Yes, the proposal suggests ALL the power of a nuke plant be used to run PUMPS
to pump the water.
Terra forming implies something truly majestic in manipulating the environment: I do not believe that it would take anything "majestic" in size at 2000 meters in height in the way of an impoundment.
The WATER would be discharged in basins already salt saturated.
Don't forget the benefit of attempting to get MORE RAINFALL further east.
(This by the way is the most problematic component, as my knowledge of meteorology is "somewhat suspect". (Scratch, pic, flick...)
Good Answers: 97
03/26/2008 12:23 AM
The words 'water will be sucked out of the ocean' brought to mind the notion of a syphon. Do I understand that syphon is not requiring outside energy.
03/24/2008 9:01 PM
RAIN, I HOPE???
Good Answers: 66
03/25/2008 2:13 AM
"RAIN, I HOPE???"
That would be an intended consequence - but what about flooding? If you introduce conditions that yield more rainfall (or even worse snowfall) than expected, or in a location not expected, what then? I'm not saying it's not an intriguing idea, only that the mechanisms that drive weather patterns are not as well understood as many of us like to think they are. Weather modelling takes up a large part of the super-computing capacity available and they still can't get a reliable 5-day forecast. I'm not confident in the ability to accurately manipulate it.
03/25/2008 1:35 PM
hello CSM Engineer,
you comment;
I believe salt water is denser oh..... and it is, check this out.
http://en.wikipedia.org/wiki/Seawater
without diving into this, my first impressions reflect yours on the practicality
phoenix911
Good Answers: 66
03/25/2008 1:40 PM
Duh, I knew that!
That's what happens when you get interrupted in the middle of writing a post, I guess. Still, no excuse...I obviously did not proof it as well as I should have! Thanks for keeping me honest!
03/25/2008 1:45 PM
I understand, when I get interupted I somet...............
Good Answers: 266
03/24/2008 5:56 PM
Some of the power plants on the east coast already utilize your suggestion. Peach Bottom Nuclear power plant over night at low usage time pumps water into a large holding reservoir about 100 ft in elevation above the pool level of the lake on which it sits. During peak hours it's drained to run turbines. I am sure something to this effect could be done on Lake Meade to curtail usage of water at the hydro plant.
03/24/2008 7:40 PM
This would sound fun but following the 'Brainstorming' idea I do have a little idea about this as following: 'Why not apply the Panama Canal or the antique Rome aqueduct systems for moving water all over the place?' I mean, that worked for them at that time and probably will save some energy as well using that same approach, I don't Know what else to tell ya' at this point, but, I do believe your point of view makes a lot of sense too. We getting there some how down the road. Soon or later someone will check up all this good ideas an improve something good out of them. Hang in There....
Nice Clue,
MC
03/24/2008 9:00 PM
None of the ideas by themselves is worth a hoot in hell,
but synchronistically, there may be some real benefit..
Somebody that knows WTFooey they are talking about in re evap rates, and if a rate of evap sufficient to perchance precipitate precipitation, yuk yuk, as the moist air heads east over the mountains......
would be a help.
out
Good Answers: 109
03/25/2008 3:42 AM
Hi,
there is only one problem: the water is available at nearly no cost to farmers
and at low cost for others.
If you rise the price to a level that is common in other parts of the world where there is a water shortage you will have a devastating impact on agriculture in California with big economical consequences.
So I estimate that there will be high prices for consumers and a little bit higher prices for farmers. High prices for consumers will be a start signal for the construction of large desalination plants: seawater to drinking water quality is available today at 1$/cubic meter. This is much lower than many people have to pay .
So most people will be more "water-conscious" that is $-conscious.
Farmers will change open irrigation to subsoil irrigation (this will save around 50%!) and maybe the very old canals will be redone that transport the water and loose up to 30% on its way by spillage and evaporation.
If the prices are risen now then this change will come in time. But if the authorities wait there will be a lot of really big problems.
This is a much bigger problem than air pollution and global warming! It will affect the total southwest of the US and not only farming and household but industry too, so the basis of wealth and living may be affected!
RHABE
03/25/2008 5:41 AM
03/29/2008 9:45 PM
OOOUUh HEElll Yeeaahh.. This is a very impresive Power House Pal'. I did like that idea of pump reversing to back up reserve level that sound smart design definetly. Great deal. Thanks for the nice data here. "Dinorwig's reversible pump/turbines are capable of reaching maximum generation in less than 16 seconds. Using off-peak electricity the six units are reversed as pumps to transport water from the lower reservoir, back to Marchlyn Mawr." Allset then have a nice weekend now...
Smart Move,
MC
03/30/2008 3:11 AM
Wot about Scotland ? You can understand the people there, almost.
03/25/2008 5:03 PM
The problem in the Colorado River drainage system is better explicated in
http://cr4.globalspec.com/thread/18013
The Great Basin is described here
http://en.wikipedia.org/wiki/Great_Basin
"The Great Basin is a large, arid region of the western United States. Its boundaries depend on how it is defined. Its most common definition is the contiguous watershed, roughly between the Wasatch Mountains, in Utah and the Sierra Nevada, that has no natural outlet to the sea. "
"Additionally the Great Basin contains
two large expansive playas that are the lakebed remnants of prehistoric lakes that existed in the basin during the last ice age but have since largely dried up.
Lake Bonneville extended over most of Western Utah and into Idaho and Nevada, leaving behind the Great Salt Lake, the Bonneville Salt Flats, Utah Lake, and Sevier Lake. Likewise Lake Lahontan extended across much of northwestern Nevada and neighboring states, leaving behind such remnants as the Black Rock Desert, Carson Sink, Humboldt Sink, Walker Lake, Pyramid Lake, Winnemucca Lake, and Honey Lake, each of which now forms a separate watershed within the basin."
"The Basin has remained among the most sparsely-inhabited areas of the United States. The two largest cities in the basin are Salt Lake City, Utah on its eastern edge and Reno, Nevada on its western edge"
For some pictures which show the HUGE SALT LADEN dry playas which would receive the ocean water, see
http://djensenphotography.com/pages/great_basin.htm
I WOULD hate to see "Black Rock Desert" be filled, as I would greatly miss
BURNING MAN..
Location: Earth. England/America -the birthplace of the C. S. A. - anywhere I imagine -home.
03/25/2008 9:36 PM
Start with Death Valley, since it is already below sea level, all you need is a big pipeline and no pumps. It might even produce electrical power as the seawater flows into the desert. Environmentalists will scream in fury at this idea and your idea, as it will change their precious environment. They don't care if the change is beneficial, just that it is a change. Salt Lake City might need dikes to protect it though, another expense and a lot of people objecting.
I think it is worth a try though.
No technology is so obsolete that it won't work. A stone knife still can kill you as dead as a laser.
03/26/2008 3:44 AM
Need one hell of suck to prime the pipe
Good Answers: 97
03/29/2008 4:49 PM
Slowly lower the pipe into the sea, when filled plug the near end then manipulate to obtain syphon.
Good Answers: 109
03/26/2008 4:36 AM
Hi,
that would be much better in Israel refilling the dead sea from the red sea.
Much debate about this but no real (economic) solution.
Energy is still too cheap.
RHABE
03/26/2008 5:56 AM
Maybe they could pipe water to theatres ?
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
03/26/2008 6:15 AM
Why not tow that huge iceburg that just broke off?
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
04/06/2008 7:08 PM
Use the Sultan Sea, from the Sea of Cortez a 230 foot drop and very low elevation to trench through to connect the two. Run the sea water out a turbine to solar evaporation green houses, producing fresh water and sea salt.
Solar Green house is a small canal with an "A" frame glass roof that condensates into side channels for fresh water collection. The leftover brine goes into ponds for final evaporation into sea salt. Aqua-farm and use the waste water to grow crops. Use some of the crops to feed the Aqua-farming.
Or some power, fresh water, and food. From free gravity and sunshine. The major cost is the Pipe line to connect the two.
One of my smaller ideas
Brad
Good Answers: 97
04/09/2008 11:44 PM
I think you've forgotten the origin of Sultan Sea...
04/10/2008 12:33 AM
Not really, the Colorado river just doesn't make the sea any more. Now the Sultan Sea is fed by the runoff of the farms. Lots of salts and nitrates.
Ya it should flood, but the respective governments have diked and damed it until it takes a "natural disaster" in an unnatural system.
The U.S. gov. even funded and built a big desalination plant, near the end of the Colorado river, that's rusting away for lack of water.
Last time I checked a Mexican sewage canal was feeding it also. This could have changed. I designed the system as a mental exercise over five years ago on how to improve the area. The major issue is 150 miles of very large pipe through two countries.
Brad
Good Answers: 97
04/10/2008 1:03 AM
Current economics may not vent your way...
04/10/2008 7:26 PM
To even get the U.S. and Mexican governments to allow it without a multitude of political strings and spins would be a lesson in corrupt politics I'd wish on no one.
Can you Imagen the environmental impact statement required.
You would need a full time lobbyist on capital hill just to keep track of whom your friends and foes are in real time. And that is even if it was self funded.
Still like the concept.
Brad
04/10/2008 8:19 PM
In my opinion, many of the "siting" issues currently having sway over contentious NIMBY arguments and rancorous "save the owl" dialogues will be swept away by emergency declarations, when the seriousness of our rapidly degrading situation becomes apparent.
The Colorado River will soon be the Colorado Trickle, and LA's apportionment will not keep their swimming pools filled.
In my opinion, (biased to be sure) this suggestion of making hundreds or thousands of square miles of evaporation ponds "upwind" from the Rocky Mountains would effectively harness the energy of the sun and more than make up for the energy used to pump the water from the ocean.
Register to Reply 34 comments
Bricktop (1); bwire (4); CSM Engineer (3); I)AVI) (7); Kris (2); MOBI (1); ozzb (1); phoenix911 (2); PWSlack (1); RHABE (2); Taganan (1); U V (3); user-deleted-1105 (4)
