i want to buy apump 2000imp galls my head is 1.2 m from outlet it s lenth is 4m 1half inch welded pipe all pipe work from outlet is flat its the price of the pump if i mention koi the pump goes up 100 pounds so i am looking at other optoins but seem to get no real advice as to where to puchase the same pump is used for many other uses but cheaper notgoing though koi outlet
We wish that you will contribute and learn from this forum.
Before we proceed to your question,here are few general tips to get the maximum out of this forum.
a) Please make your question as detailed as possible, more details you give the better answer you will get.
b) Avoid writing in CAPS as that is considered as shouting in this forum.
c) If any suggestion given by the member actually satisfies you, or does not solve your problem, keep that posted.
d) The members of this forum try their best to solve the problems and do have a very good command on the subject.
e) You will be surprised to see the amount of info, archives hold here..so do a search on here or at Mr Google, and in case you don't get anything you are welcome to post your query.
f) Do not use rude remarks and country/religion/ethnic background/poiltical innuendos, in your comments.
Post this at Meachanical Engg section too,..guys there will love to answer this one...
Here one factor ( Head) is to be known....how many meters do you have to send the water.
Your flow is 7.5 m3/hr (assuming 2000 USgph) and if you have to send it say 50 meters then you will require a 1.5 hp centrifugal pump.
Now as your head (50 m) comes down the hp will reduce.
Cheers.
He must be very ignorant as he answers all the questions he is asked. Voltaire
