Previous in Forum: "Smart" Barrels to Make Chemical Storage Safer   Next in Forum: Bubbly Space
23 comments
Popular Science - Weaponology - New Member Hobbies - Musician - New Member
Anti-gravity
06/20/2006 3:13 PM
Is anyone working on an anti-gravity device? We all know that all mass has gravity; so would the answer be anti-mass or negative mass in order to build a usable device?
Pathfinder Tags: anti-gravity Gravity
Good Answers: 918
Coming Soon
06/20/2006 3:17 PM
It's in the queue! However, the time machine project has all our resources tied up right now.
I am working on a "anty-gravity" reactor!
06/20/2006 11:08 PM
The word anti-gravity must be defined in a different way than to day! The thing with "anti-gravity are that you are shielding the mass properties from the physical world and then you got a mass that does not react to the earths gravitationally field The secret are to shield the mass with a frequency that is non natural! Then you get zero properties in the mass. I am working day and night with my prototype and it seems to me that it's like a trip into a new dimension! Robert Myrland Norway
Engineering Fields - Aerospace Engineering - Retired South Africa - Member - The Rainbow-nation Engineering Fields - Engineering Physics - Relativity & Cosmology Popular Science - Cosmology - The Big Picture!
Good Answers: 69
Re:I am working on a "anty-gravity" reactor!
06/21/2006 2:56 AM
Anti-gravity does apparently exist in nature. The Big Bang is thought to have happened due to some quantum fluctuation causing a form of anti-gravity. Today, the large-scale universal expansion seems to be accelerating rather than being decelerated by gravity - another form of anti-gravity, thought to be related to Einstein's cosmological constant.
The problem seems to be that anti-gravity only works on the extremely small (quantum scale) or the extremely large (cosmic scale). It further seems to be impractical to screen anything from the effects of gravity – gravity is caused by space-time curvature and the energy required to change that curvature is enormous… so good luck!
06/21/2006 8:33 AM
Yes, there are 3 frequencies when combined in a device sheild the mass... I may have the key Keyholder Lets get a grant from Bill Gates and finish this!
06/21/2006 1:09 PM
I believe this is possible, what type of financing do you need.
06/21/2006 11:25 AM
I believe you are on the right path. Someone was able "by frequency" that lifted and held an autombile 3 inches off the ground.
06/21/2006 12:19 PM
Where? When? I'd like to see the article if there was one.
Good Answers: 69
06/21/2006 1:35 PM
I heard about this "lifting of the automobile" - but I think the original article was about somebody dreaming...
06/26/2006 3:19 PM
Have you had any success?
07/05/2006 2:31 AM
Hi, it is very interesting what you are doing, but can you define what the MASS is?. I think, before we (as a humankind) do not understand fully what it means Mass, Force, Frequency etc. everything in this direction will be only a guessing. Regards Miroslaw
Re: I am working on a "anty-gravity" reactor!
12/21/2008 1:32 AM
7 years ago i woke up with the knowledge of how to make antigravity and its a totally self running cantained power source. email at c.hubbard30@yahoo.com
Bouyancy force
06/21/2006 3:02 AM
See, every body on the earth is acted upon by many forces , but if we consider two forces i.e. Gravity force and Bouyancy that are acting on the body on earth, the antigravity will mean that you have to increase the Bouyancy force on the body. At present the gravity force is more than the bouyancy force on the earth surface,but it is approximately equal in water. So according to me the only way to work on antigravity is to concentrate and work on Bouyancey force.
Happiness is in your hands, Open your hands...........
Re:Bouyancy force
06/21/2006 8:16 AM
All of you are all wet! The opposite of gravity is comedy! Everything you know is wrong!
Good Answers: 18
Antigravity
06/21/2006 9:52 AM
Most of the time, rockets seem to work as "usable device(s)."
OK, I'll bite...
06/21/2006 11:08 PM
Gravity is not caused by the curvature of space and time, and buoyancy is only applicable in liquids and gases. (Ok, arguably, it works in solids, too, but the man is trying for a practical way to do in gravity.) So here you are:
Gravity, like light, is a wave/particle. Most things (maybe all things, who knows) appear to be gravity transparent, so unlike light which is easily stopped by aluminum foil or even dirty windows, you aren't going to be picking up any 'gravity screens' in the near future. If you could I would wear them in my shoes when being weighed in at the annual physical.
Like most natural sources of light, gravity is non-coherent (as opposed to incoherent) so you'll have a lot of difficulty building a wave-based shielding system. T'won't be as easy as the stealth tricks used for radar.
BUT you could build an effective gravity generator, conceptually similar to a laser. It wouldn't push things around, but it could pull them.
All you need (and the word "all" is facetious here) is a controllable source of gravity - something that could burst it out to be the trigger and a medium to do the 'amplifying'.
There are many possible materials for both and now you get to be like Edison, and first learn of a few thousand that don't work.
Bonne Chance
Re:OK, I'll bite...
06/22/2006 1:13 AM
Since everything is made of vibrating energy, you just have to tune in to the right frequency. Those levitating mystics can do it. I think you'd have to study a lot of Eastern mystical practices, as well as a good dose of buddism, hinduism, and shamanism. It's more than just mind over matter. Once you get yourself levitating, the trick would be how to harness those frequencies and apply them to an object other than one's self. What's the frequency, Kenneth?
Those who think small, stay small.
Good Answers: 69
Re:OK, I'll bite...
06/23/2006 2:49 AM
Quote: "Gravity is not caused by the curvature of space and time, and ..."
This view is in total disagreement with Einstein's theory of relativity. It is only in agreement with a (as to date unworkable) hypothesis called 'quantum gravity' - in fact there are quantum gravity theories that do not depend on the particle that you refer to (I presume it is the hypothetical 'graviton'). A quick Google or even Wikipedia search will shed more light on this.
But yes, IF the graviton exists and IF one can 'produce' it in sufficient quantity, you may pull things towards the source.
Anti-gravity
06/22/2006 1:57 AM
you have in mind high temperature superconductor Gyro?
Re:Anti-gravity
06/30/2006 9:43 AM
I found an intersting item called a "lifter" that uses 20-30 KV, made out of balsa wood, aluminum foil and magnet wire that floats in mid-air with no moving parts! jnaudin.free.fr/html/lifter1.htm
Re:Anti-gravity
07/05/2006 2:25 AM
Thanks. I have saw it before - it's more like a toy for the "big boys" (just Brown Effect). But look on the FESTO web side www.festo.com, and give in the search b-IONIC. It is very interesting what so big company like FESTO do with their "cash", isnt't it. Regards Miroslaw
Re:Anti-gravity
07/24/2006 11:50 AM
I think your all talking about creating an equal but opposite force (slighty higher to levitate and then maybe put a gyroscope on board to move laterally) will do the trick! Since we all know that the 1G is a function of M and gravitational constant, this rules out putting a giant rock in space near the earth, cause if that happened we might have a larger problem on our hands, yet I am okay with the moon moving the tides. Anyway - Maybe a focused magnetic / electric field from space with Mighty Mouses ray gun to your opposite polarity people mover, will provide enough pull to suck you off earths surface, just hope he does not loose focus from space, cause the drop out of the air can really dampen your day.
Re: Anti-gravity
12/01/2007 3:05 PM
It's like the law for evert reaction there is an opposite and equal reaction. So just find the objects gravitional force and do the opposite.
Re: Anti-gravity
09/01/2012 2:02 AM
I know how to defy gravity,travel faster than light and control alpha to omega with magnets, also pi is changed to 3.125. I know how to create this naturally to create energy like super collider, its not electric or light its energy a mixture of both like lil specs of white energy I see everywhere its what everything is made of which has been created 3 other times before the planet redoes itself which causes population control thru iceage. The red sea was split by carving cave under it to escape and caved in on followers which made it split till water reached bottom and come back together on enemy's, that where a wood staff is interperated cause one wood was supporting cave until pull to split sea by collapsing it. My invention is the Ark of covenant but I know how to stop reaction to be able to enter center magnet which is always 0 gravity like sun. Which cancer will go away, time is non existant like in genisis we will live longer and to travel without propulsion but by manipulating center magnet out of center with concept similar to plasma globe and outer magnet will always try to catch up to where center magnet is back center. I know how to contain and control energy of nazi bell. Its my destiny to find help in building this for humanity to advance in next stage of evolution to the galactic level. When I find help or funding it will be built and save us from what's coming with our planet recycling itself and when this happens if its not built only the ones able to get to .underground Will survive and rest will suffer and die from extremities
Register to Reply 23 comments
Anonymous Hero (1); Anonymous Poster (5); Bill (1); chub (1); GravKeyHolder (1); jdst (1); Jorrie (3); kbinnj (1); screenjam (1); solaank (1); solincsteve (1); steve-o (3); Vortex (3)
