This is a quickie! (I hope!)
Following further to my experiments with electronics ( there are a few diodes so that would class it as electronics!
) and the remote controlled pea shooting cat scarer on my roof (with a long cat 5 cable!!) I have the following set up. 2off 24Vac motors to give me my up/down and left/right and a solenoid trigger set up! Up to now, no problems, all works well! I use a little 24Vac transformer which also has a 12vac tap. Now, for the air side of it! I have a 12vdc central locking air pump from a car that I want to use.
Can I rectify the 12vac to 12vdc and connect the pump without causing any ill effects to the other circuits or the transformer?
In Spain and out of my depth! Cats have started to take residence on my cat so to speak!
A quick note Del! I am using this pump so that I don't blow holes in the cats, only give them a little flick on the ass! I intend to give the cats a fighting chance by using a web-cam, and limiting the number of shots to 3 before I have to start the pump to get back up to pressure! Bit of a daft idea I know, but can't think of anything more entertaining than a fair fight! They have won for the last 8 years so now it's my turn!!
