Previous in Forum: Overvoltage in AC Motor Windings   Next in Forum: Over Excitation and Under Excitation of Generator.
14 comments
Mercury Switch
04/04/2008 5:55 AM
i am designing a system requiring a mercury switch but fortunately i can nto get this switch. what simple equivalent switch can i use which serves the same purpose as the mercury switch .
Good Answers: 230
Re: mercury switch
04/04/2008 6:25 AM
Hello Guest,
Mercury switches are not used so often now, because of the toxicity of mercury metal and vapour at room temperature, of the glass phial is broken.
Try a Reed Switch on the fixed part, and a permanent magnet on the moving part.
Advise whether that would be suitable.
Kind Regards....
Re: mercury switch
04/04/2008 7:54 AM
Re: Mercury Switch
04/04/2008 11:41 AM
Do you mean a tilt switch? Or a switch with wetted contacts? Or what?
Re: Mercury Switch
04/04/2008 12:11 PM
absolutely a tilt switch, i want to connect some triggering devices pararllely to an alarm.
Re: Mercury Switch
04/04/2008 12:53 PM
i want to to use other switch instead of tilt switch
Re: Mercury Switch
04/04/2008 5:07 PM
Please explain why you want to want to trigger something from detection of a tilt.
Also, please register.
Good Answers: 50
Re: Mercury Switch
04/05/2008 1:54 AM
I think what everyone is too timid to ask is "Why do you want to use a device that is typically used in terrorist bombs?"
Re: Mercury Switch
04/05/2008 4:47 AM
I wish terrorists would use them - as they are not easily portable they could blow themselves up.
Suggest a ball bearing in a plastic tube. will do same thing. Ball has to make contact with two filaments. If you can get a brass ball (pawnbroker) you will get better contact but if steel ball is heavy enough it should work. Sparking could cause erosion so best if tube is filled with nitrogen (liquid would be easy - local medics have flasks) or helium (from a novelty shop - buy a balloon full)
You can always tell the pioneers - they are the ones with arrows in their backs.
Re: Mercury Switch
04/05/2008 8:30 AM
I am looking for a self leveling platform. Could this switch work in this type of device?
Re: Mercury Switch
04/05/2008 10:13 AM
FOR A SELF LEVELLING DEVICE A PENDULUM ACTION IS USUALLY NEEDED (e.g. GIMBALS)
BALL SWITCH WILL WORK SAME AS MERCURY - KEEP BALL SMALL FOR FINITE WORK - HEAVY BALL WILL MOVE MORE VIOLENTLY - HIGHER ENTROPY.
BALL BEARINGS ARE QUITE GOOD FOR CHECKING FLOOR LEVELS AND OTHER SM0OTH SURFACES. ANY ROUGHNESS WILL MEAN A BIGGER BALL IS NEEDED
NOT QUITE SURE HOW YOU WANT IT TO OPERATE - WILL SWITCH ACTVATE A SOLENOID OR A MOTOR? REMEMBER IT IS STRICTLY ON/OFF - NO MODULATION.
Re: Mercury Switch
04/07/2008 3:29 AM
Good Answers: 15
Re: Mercury Switch
04/07/2008 7:51 AM
Find an Old round style furnace thermostat and take it a part. The use mercury switches. Not sure if the old style thermostats sold in the big box hardware stores still have mercury in them or not.
scotchdrnkr
United States - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
Re: Mercury Switch
04/07/2008 2:43 PM
Hello Guest,
Mercury-based tilt switches are becoming harder to hind (due to toxicity), but you can now buy tilt switches without mercury. For example:
http://machinedesign.com/ContentItem/714/68041/TiltSensorSwitch.aspx
Problems worthy of attack prove their worth by hitting back. -- Piet Hein
Re: Mercury Switch
03/03/2009 2:13 AM
Oncque Corporation is a professional manufacturer of Roll Ball Switch and Vibration Switch in Taiwan. Founded in 1996, Oncque has developed a lot of new specification and new designed Roll Ball Switch and Vibration Switch in few years. Until now, Oncque gets more than 10 kinds of patents in this professional field.
You can visit its website, www.oncque.com, for more information!!
Anonymous Poster (4); hazman (2); jimhouse@windstream.net (1); JohnDG (2); Randall (1); scotchdrnkr (1); Sparkstation (1); svengali (1); vermin (1)
You might be interested in: Switch Boots, Audio Switch Matrices
