Previous in Forum: LPG Loading Automation System   Next in Forum: gear motor
Metric Air Flow Formula
04/05/2008 4:50 AM
The Metric Air Flow Formula?.
Re: Metric Air Flow Formula
04/05/2008 5:02 AM
"The Metric Air Flow Formula?."
This pseudo question is cryptic to the point of being meaningless.
Please try again explaining what it is you want to know and maybe the application....
We are not psychic..we do not know what area of endeavour you are working in...it could be anything from heating and ventillation to respiratory medecine.
04/05/2008 5:56 AM
The question is about the simple metric formula of air flow through pipe either under vacuum or pressure at standard air temperature.
Thanks.
04/10/2008 7:51 AM
It needs to be placed in context before a meaningful answer can be given. What is being discussed here? HVAC? Wind tunnels? Instrumentation piping? Size is important!
04/10/2008 8:22 AM
Thanks for your kind attention.
The question is about the volume of air deivered by blower under 0.5 kg/cm2, through
through instrumentation tube of 5 mm diameter, with length of one meter to the load.
Kindest regards.
Hammamy
04/12/2008 2:07 AM
Dear friend,
Many thanks for your kind attention.
I have posted response, but is blocked?, I don't know why.
The question is related to air flow in instrumentation pipes of 5 mm inner diameter with one meter length, under either pressure or vacuum of 0.5 kg/cm2.
I appreciate your care.
Kindest regards.
Hammamy
04/16/2008 3:00 AM
Kindest regards.
Hammamy
Register to Reply 6 comments
Hammamy (4); PWSlack (1); user-deleted-1105 (1)
You might be interested in: Metric Gears, Gas Flow Meters, Flow Meters
