DEAR FRIENDS,
VERY GOOD MORNING.
PRESENTLY I AM WORKING WITH THE TRUCK TANKER AUTOMATION SYSTEM WHERE LPG IS BEING LOADED USING MASS FLOW METER. THE SYSTEM IS CONTROLLED THROUGH A BATCH CONTROLER AND IS WORKING FINE. HOWEVER I NEED SOME SUGGESTIONS FROM YOU ALL REGARDING SOME PROBLEMS I AM FACING:
1. THE READING IN THE MASS FLOW METER IS BEING CROSS REFFERED BY THE WEIGH BRIDGE(OLD SYSTEM FOR LOADING, WHICH IS WIDELY ACCEPTED). HOWEVER IT IS SEEN THAT THE READING OF MASS FLOWMETER AND WEIGH BRDIGE DOESNOT MATCH MORE OFTEN. WHAT CAN BE THE POSSIBLE REASONS? ERROR VARIES FROM 60 TO 150 KG WITH WEIGH BRIDGE SHOWING ON HIGHER SIDE.
2. THE VENDOR OF BATCH CONTROLLER SAYS THAT THE MASS FLOWMETER(MAKE ENDRESS & HAUSER) IS BEING FACTORY CALIBRATED WITH WATER, SO AT SITE WHILE MEASURING THE LPG ITS READINGS WILL NOT MATCH WITH THE WEIGH BRIDGE. SO HE HAD PUT A MULTIPLYIING FACTOR IN THE BATCH CONTROLLER TO MATCH THE RESULTS. (THE WEIGH BRIDGE CAL HAS BEEN CHECKED).
NOW IS THAT WHAT THE VENDORS SAY IS FINE? IF I MEASURE LPG, WILL THE ORIGINAL CALIBRATION(WITH H2O) WILL VARRY? WE HAD ALREADY GIVEN ALL THE PROCESS PARATMETERS BEFORE PROCURRING THE SYSTEM, SO THE E&H PEOPLE SHOULD HAVE TAKEN THESE FACTS INTO ACCOUNT.
3. THE MASS FLOW METER COMPENSATES FOR DENSITY OF ITS OWN? SO HOW THE CALIBRATION WILL CHANGE?
THE ABOVE QUESTIONS NEEDS ALL OF YOUR VIEWS....PLEASE HELP....
