I am trying to replace the stock lightbulb in my Mitsubishi Lancer Evolution's 3rd high mount stop light. From the factory the car has a 7440 bulb. I took this bulb out and measured it with an ohm meter and it measures about 1.0 ohm.
What I did was to buy the LED style bulbs that plug directly into the stock harnesses. These are replacement bulbs that fit the same as the stock bulbs. They are simply plug and play. I have done my reverse bulbs, and my brake lights.
The problem that I am having is that I am trying to fool the cars computer into thinking that the stock bulb is still in the 3rd brake light. My car has a sophisticated All wheel drive setup with sensors that look to see if the ABS is on. It gets this signal from the 3rd brake light. On typical cars, when you dont press the brakes, there is 0 volts at the rear 3rd brake light. On my car, when the key is on, it has about 1 volt. Since I have the LED in there, it gets funny and causes an ABS sensor error causing a lightup on the dash. Obviously when I step on the brakes it goes to 12-14 volts. The bulb appears to light up fine, it just causes this error after driving the car for 20 minutes or so. It goes away if i turn off the key and start it again.
My plan was to put a 50 watt resistor of 3 ohms in parallel with the led. If I get desperate I can put the stock bulb in parallel with the LED right?
Some things I measured....
The LED when put on a 12V battery directly draws about .2 amps. The incandescent bulb draws about 1.87 amps. I put a current meter in there to measure it.
if someone can help that would be great.
my email is djturbojp7@yahoo.com
