Previous in Forum: Pipeline Valve Testing   Next in Forum: Torque Valve for Plastic Spacer into Metal
Blower delivery calculation
04/14/2008 11:26 AM
iamhaving a blower which is fitted with 7,5 hp motor 550 mm impeller 50 mm thik 8 blades welded on the impeller running at 2880 rpm what is the CFM 1 want to modify the blower to 3500 cfm what should i do
Re: Blower delivery calculation
04/15/2008 12:01 AM
Hi,
550 mm means OD or ID ? CFM is a function of ID (inlet area) and RPM ,lead angle(blade angle with tangent of inlet cicle) .for increase the flow you should increase the speed or increase the id of impeller .but your case speed increase is not possible as already it is high.hence you change the fan.dont go for alteration once you know through knowledge
10/02/2024 7:20 AM
The first thing to do is pick up the 'phone, and then talk the proposal through with the original equipment manufacturer.
