I am the client's safety manager on a large construction project. Our civil's contractor has made sorting hooks for lifting concrete (spun cast) piles. These are cut from 20mm steel plate in the form of a square C and one hook is placed at each end of the pile. They have provided calculations to show the tensile strength is more than capable of taking the load. My concern is that lifting gear is normally forged and heat treated to ensure not just tensile strength but other properties like resilience and toughness. The forgings also have profiles that provide lateral support to prevent twisting. The calculations for the fabricated hooks assume that the hooks are placed perfectly every time and that there is no tip loading of the hook. Another concern that I have is that it has been assumed that the hooks will fail in shear but I know of job made lifting gear failing by deformation and slipping out of the load. I have stopped the job and have asked for a different lifting method to be employed using proprietary lifting gear. I would appreciate comments on whether my approach is reasonable or am I being too conservative. If you think job made lifting gear is OK what safeguards should I insist on?
