Have set of HP air standards. Have been calibrated by outside vendor and here in house.
Have a capcacitance meter that came back from repair and failing on kHz on DF for about every check listed in manual. Vendor saying since we do not have DF values from calibration, they say it is our standards. Tested 13 other of the same model and can not get any to fail. Followed their procedure on all as well as ours (which was virtually the same).
I feel the unit is not repaired right after so many other pieces passing and the air standards do not calibrate the equipment, only see if can read the standard within spec.
Any suggestions?
