I need recommendations on using a gps unit (www.beehivegps.com - a Utah company) that is cheap, but good, to monitor fluid level in a tank that is roughly 20 feet tall and 15 feet in diameter. I need to have the gps send me a signal so that I know when it is full enough so I will not waste a trip out in the back 40 (way-back 40) with an expensive tanker truck and an employee. The fluids we haul are oil field production water with some petroleum products mixed in. Please help me determine the type of sensor system to use. This gps has both analog and digital input and output capabilities so the sensor should be compatible with one of those by cable. We have 12 volt power and sometimes electric depending where we are working at the time. Please write to me with suggestions. Thanks, Miss Queenbee
