Previous in Forum: microchip(.com)   Next in Forum: Center Finder needed (NOT for round objects)
WIND ENERGY
04/28/2008 2:07 AM
Wondering if a wind turbine is the same as a windmill ?
Re: WIND ENERGY
04/28/2008 4:33 AM
It is a matter of semantics..
No two different things are ever 'the same'.
They are 'similar' it depends how much detail you want to go into.
Simply put..the inputs are the same ...the out puts are different.
Wind drives them both...a 'Mill' grinds or mills something. A turbine.... presumably is going to generate electricity.
I'll let you figure out the bits in between.
United States - US - Statue of Liberty - Sworn to preserve and protect Engineering Fields - Nanoengineering - How tiny is it? APIX Pilot Plant Design Project - Member - Good idea. Engineering Fields - Engineering Physics - Engineering Fields - Energy Engineering - Energy in Transition
Good Answers: 15
Re: WIND ENERGY
04/28/2008 2:54 PM
Del,
I had thought of turbine as being like a gas turbine or steam turbine - many blades on a set of discs that rotate wehn appropriate gasses pass through them. And that tall thing with rotating blades that generates electricity as a wind generator (equally inappropriate phrase - it does not generate wind.) Feeling lost in the semantics I looked it up in Wikipedia, and found the following:
Wind turbine
From Wikipedia, the free encyclopedia Jump to: navigation, search
Wind turbines near Aalborg, Denmark. For scale, a standard doorway can be seen at the base of the pylon.
A wind turbine is a rotating machine that converts the kinetic energy in wind into mechanical energy. If the mechanical energy is used directly by machinery, such as a pump or grinding stones, the machine is usually called a windmill. If the mechanical energy is then converted to electricity, the machine is called a wind generator, wind turbine, wind power unit (WPU) or wind energy converter (WEC).
xxxxxxxxxxxxxxxxxxxxxx
It is always good to improve ones education and knowledge. Thanks.
“Truth is stranger than fiction, but it is because Fiction is obliged to stick to possibilities. Truth isn't.” – Samuel Clemens in Following the Equator, Pudd'nhead Wilson's New Calendar
Re: WIND ENERGY
04/28/2008 7:50 AM
A windmill, traditionally, is a wind-powered device that is used to mill grain. This one has 4 sails:
A wind turbine is a wind-powered device that makes electricity. This one has three blades: There are similarities.
Good Answers: 97
Re: WIND ENERGY
04/28/2008 10:18 AM
In SA (I think OZ as well) the word windmill is also used for a wind driven reciprocating bore hole (bore well) pump.
Re: WIND ENERGY
04/28/2008 1:53 PM
Ah well <tee hee>... that's the colonials for you
Hendrik (1); PWSlack (1); user-deleted-1105 (2); v1sor (1)
