Previous in Forum: How Do I Start A Service Of Removing Sedimentation From Big Petroleum Tank?   Next in Forum: MOC of Sulphuric Acid Storage and Handling
28 comments
Good Answers: 50
Porous Membrane
04/29/2008 8:07 PM
OK. Let's see how good the chemists are on CR4...
What can you recommend (or what would you use) to separate two aqueous solutions such that the chemicals on either side of the separator will not mix, but it will allow them to exchange of + and - ions?
Any ideas???
Thanks!
Good Answers: 101
Re: Porous Membrane
04/29/2008 10:16 PM
Electrodialysis. It will draw all the cations to one side and the anions to the other.
Good Answers: 50
Re: Porous Membrane
04/30/2008 12:02 AM
You mean like the machine or are you talking about some sort of membrane? More info would help.
Thanks for the answer.
Good Answers: 101
Re: Porous Membrane
04/30/2008 4:55 AM
It's a process. It uses a machine called an electrodialysis stack. It uses high voltage DC power and 2 special types of membrane. One type is permeable to cations but not anions, and is mated to the negative terminal, while the other type is permeable to anions but not cations, and is mated to the positive terminal. In this way, the anions will be drawn to the anode and the cations to the cathode, resulting in the solution being separated into acid and base.
Good Answers: 50
Re: Porous Membrane
04/30/2008 5:05 AM
So what are the two materials?
Here's what I'm trying to do... I'm trying to create a battery using two half cells that act together to make a single cell. Here's a picture from Wikipedia:
What is that damn "Porous disk" made of - it's driving me nuts!!!
Good Answers: 101
Re: Porous Membrane
04/30/2008 5:45 AM
Honestly, I don't know what the 2 types of membrane are made of as I design water treatment systems, not membranes. Veolia Water or GE-Ionics, who do manufacture such stacks, will probably be better placed to advice you on this. Other membrane manufacturers such as Hyflux may also be able to tell you more. In this case, you membrane needs to be permeable to both cations and anions. It is the DC charge that separates them. In fact, if you show the membrane manufacturers or their agents the diagram, they'll probably be able to tell you what type of material it is.
Good Answers: 50
Re: Porous Membrane
04/30/2008 11:59 PM
The Gore corporation told me they make theirs out of a micro-teflon felt, but if I wanted a sample, I'd have to cough up $500.00!!!
By the way, they're the same people that make Gore-Tek.
Re: Porous Membrane
04/30/2008 8:10 AM
http://en.wikipedia.org/wiki/Daniell_cell
It looks like a porous ceramic can be used (a flower pot would be the suggestion for the enthusiastic home experimenter or Myth Buster watcher, perhaps?), or failing that a salt bridge made of either sodium sulphate or potassium sulphate, both of which are highly soluble.
The original voltaic pile used cloth or cardboard soaked in brine (salt water), so it would appear that there is little need to keep the two solutions separate.
United States - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
Re: Porous Membrane
05/01/2008 10:58 AM
Yes, for the type of cell vermin has in mind, the barrier between the two half-cells need only prevent bulk mixing (it lets ions freely diffuse in either direction). I have heard of porous ceramics, cellulose dialysis membranes, and cellulose paper and cloth used in this way.
Yes, a salt bridge would also work nicely -- actually even better than a porous ceramic barrier since the latter would still let some copper ions (Cu2+) react directly with the zinc metal (Zn0) electrode (which wastes some of the energy content of the cell).
Actually, this cell does need a porous barrier or salt bridge between the two half-cells. Otherwise the copper ions (Cu2+) will plate out directly onto the zinc electrode, thus wasting chemical energy since the electrons from the zinc metal combine directly with the copper ions without passing through a load:
Zn0 + Cu2+ --> Zn2+ + Cu0
Problems worthy of attack prove their worth by hitting back. -- Piet Hein
Good Answers: 50
Re: Porous Membrane
05/01/2008 11:51 PM
Thank you! That was a very good post. I'm glad you understand the processes involved in half-cells! I'm going to vote you a good answer!
PS: I really do like your avatar!
Re: Porous Membrane
05/02/2008 1:09 PM
Vermin,
you're welcome. This thread interests me very much since I actually experiment with home-made batteries as a hobby. I felt tempted to share some of my experimental results here, but they relate too closely to a potentially patentable idea of mine (I know that battery technology is already a very mature field, but I won't yet abandon my goal of contributing something original). Well, maybe I can describe one battery that is unrelated to my secret work. Using only materials available at a hardware store, I think that I can exceed the performance of the batteries proposed so far.
P.S. I still plan to explain the images in my avatar, and what they mean. But that will have to wait since I'm smack in the middle of finishing one teaching semester, and beginning a new one.
Re: Porous Membrane
05/04/2008 8:38 AM
I'm so glad that was clarified. I'd add more, but all the smillies have gone !!
Good Answers: 32
Re: Porous Membrane
05/01/2008 10:04 AM
Anything that is porous, but does not allow gross mixing of the two liquids will work. So you could actually separate the two half cells with a thin tube, fritted glass, porous ceramic, porous polypropylene, a salt bridge, Goretex or other porous plastic etc.
If you are really getting into it, I am sure you can buy a device specifically designed for this at a scientific supply shop. This kit looks like it will do exactly what you have described, and more:
http://wardsci.com/product.asp?pn=IG0007475&sid=2008FS&eid=2008FS&mr:trackingCode=2039F3B7-5A16-DD11-AD5F-000423C27502&mr:referralID=NA&bhcd2=1209649578
For home experiments, you can use real cellophane (from a cigarette pack) or a lambskin condom (without lubricant). I'm serious. Tyvek should also work.
Gore does not want to deal with small orders. If you look up expanded or porous Teflon, I'm sure that you will find something suitable.
Are you trying to duplicate the cell you have shown, or something else?
Tad
Good Answers: 50
Re: Porous Membrane
05/01/2008 11:56 PM
I'm using that basic configuration, but my chemistry will be different.
You're right about Gore Corp. (GoreTex), they want big bucks for just a small sample.
I will check out the kit.
Thanks.
Good Answers: 50
Re: Porous Membrane
05/02/2008 12:09 AM
By the way, I actually have thought about using those condoms!!!
Good Answers: 109
Re: Porous Membrane
05/01/2008 5:59 PM
Hi Vermin,
something is disturbing me with your picture.
The cation flow is driving the Zn++ through the membrane and electrons neutralise the Cu++ so Copper will be deposited and the solution will be only zinc-sulfate on both sides.
So why to use a membrane?
RHABE
Good Answers: 50
Re: Porous Membrane
05/02/2008 12:12 AM
I think the copper ions go the opposite way, entering the zinc sulphate solution.
Good Answers: 109
Re: Porous Membrane
05/02/2008 4:11 PM
Hi vermin,
the picture says (and this is correct): influx of cations (to the right)!
This is driven by the electrons that travel in the wired connection between the poles, searching for and attracting positive ions to discharge.
Copper will be plated out first as being much nobler than zinc.
RHABE
Re: Porous Membrane
04/30/2008 11:24 AM
PWSlack has the right idea with ceramics. Many fuel cells use a sintered ceramic as the ion exchange medium. It might be possible to use a sintered stainless steel, but the porosity with this material is not as uniform or as small as the sintered ceramic.
Hope that points you in the right direction.
All this worldly wisdom was once the unamiable heresy of some wise man. -Thoreau
Good Answers: 50
Re: Porous Membrane
05/01/2008 12:03 AM
Three questions...
  1. How thick should the ceramic be?
  2. How do I sinter it?
  3. What type of ceramic?
Good Answers: 18
Re: Porous Membrane
05/01/2008 9:57 AM
Generally, Potters For Peace (PFP) kneads ground, screened sawdust (or rice hulls, etc.- really any granular, fine combustible material should work) into the mix with the clays for then form their pots before kiln firing. The issue they often face is how to guarantee the consistency of the clay-sawdust consistency before forming, as this obviously affects the porosity of the finished product (after firing). These pots are used for filtering contaminated water; pore sizes ~ 2 micron are supossedly achieved.
I am wondering about whether some sort of "salt bridge", such as was used in our chemistry classes years ago could work for you?
Re: Porous Membrane
05/01/2008 12:14 PM
1. Thickness of the ceramic membrane is dependent on the time, temperature and pressure that your system will exhibit. So without knowing more about your system I can only recommend reviewing thermodynamic and rheological principles to determine that for yourself.
2. There are many sintering methods to choose from. Some people have mentioned wood burnout, which is a very good and relatively simple process, but uniform pore size is an issue. I would recommend a sol-gel process or a fine ground polymer burnout method to ensure uniform pore size.
3. The type of ceramic often depends on your system and without knowing more about it I can't say for sure because of reaction issues. But for cost effectiveness I would recommend alumina and for corrosive resistance I would recommend a sialon. Many people are recommending Earthenwares as a ready made product, but these are generally low grade, non-uniform porosity, and have poor corrosion resistance. If your process is more dependent on time and cost effectiveness over purity, this may be a good route. Otherwise I wouldn't recommend it if you are concerned about purity.
Re: Porous Membrane
05/01/2008 5:09 AM
Have a look at molecular sieves. A membrane can be formed inside a porous pot dividing wall. This could be fired clay or plaster you just have to get the two reactants to meet in the middle - put one on one side and one on the other. Fill porous plant pot with one and submerge it in solution 2.
Also check out osmosis.
You can always tell the pioneers - they are the ones with arrows in their backs.
Re: Porous Membrane
05/01/2008 8:13 AM
In protein chemistry purifications and those of other macromolecules where relatively small ionic materials (salts) are present, it is convenient to merely place an aqueous solution of the materials in question in a plastic bag of known porosity and suspend this in deionized water to effect removal of the salts by simple osmosis.
Popular Science - Weaponology - Cardio-7
Re: Porous Membrane
05/01/2008 10:19 AM
Hey, Vermin! There are a really wide number of "porous membranes" out there, capable of passing everything from ions to atoms to molecules and even really big chunks! The medical industry often uses porous ceramics for implants, especially for bone repair where the pores allow "biological fixation" to anchor the materials permanently. These ceramics are typically Al2O3, polycrystalline, or hydroxyapatite-coated porous metal sheets. For pore sizes > 100um, bone grows in the ceramic and acts as a "scaffold" for bone formation. There are polyurethane membranes that will pass only blood glucose, for example. There are techniques to construct various pore sizes. The older techniques called for adding very small crystals of salt, starch, sugar, etc to the membrane as it was formed, then dissolving away the soluble materials. Some of the membranes available include PTFE, polyolefins, silicone rubber, polyimides, polyurethanes, and so on. There are several hundred suppliers, from Asahi Glass (ion exchange membranes) to American Polyfilm, Air Products makes gas separation menbranes to concentrate nitrogen, etc. Millipore has been in the membrane industry for many years. Any of these companies can give you more physical chemistry on the process of separation, ion transport, etc. Good luck!
United States - Member - American by birth,southern by the grace of GOD Popular Science - Weaponology - you can't carry that! Technical Fields - Technical Writing - why can't I use a pencil? Hobbies - Target Shooting - New Member
Re: Porous Membrane
05/01/2008 1:53 PM
It would be a good idea to contact a company called PUR-FLOW in North Carolina. They are a water purification group, but they have a great EDI, (Electronic de-ionization). Its all in one compact unit. it can be used to make "heavy " water and also remove gasses. The more purified water is, the more aggressive it is and the more it wants to equilibrate to what it is in. So I am sure it can handle almost any liquid. Hope this can be a start.
The more complex the mind, the greater the need for the simplicity of play... If you think you can or think you can't you'll always be right
Re: Porous Membrane
05/02/2008 8:47 AM
It depends on the concentration of aqueous solutions and size of the molecules and ions. Ideally a fluoro polymer with controlled permeability would be best. (A ~76% Flourine based plastic ?) But the problem with fluoroplastics is that they are highly impermeable - But flourine is the most electronegative on the periodic table so it would have been an ideal layer for ionic transport.
So try a fluorosilicone based film to separate them. Silicone is very permeable and fluorine content might help in transporation of the ions? Hope this helps-- Venu
Materials and Process Engineering Guy
Good Answers: 50
Re: Porous Membrane
05/02/2008 3:38 PM
Last night, I purchased some very thin film Teflon. And have request for quotes in at a company that makes porous teflon. This might work.
Re: Porous Membrane
05/02/2008 1:12 PM
Register to Reply 28 comments
agua_doc (1); Anonymous Poster (1); Ben Bonsens (2); Bodepudi (2); Cardio07 (1); DVader1000 (3); hazman (1); Kris (1); logix101 (1); PWSlack (1); RHABE (2); svengali (2); Tad (1); vermin (9)
