Previous in Forum: Abstract for Project in Biomedical Physics   Next in Forum: Hydrocarbons on Saturn's Moon Titan are Biological in Origin?
diesel fuel BY products
05/11/2008 2:08 AM
what products can we produce from diesel fuel as the main ingridiant
Re: diesel fuel BY products
05/11/2008 11:27 PM
Depends on quantity at your disposal--and predictability of supply into future.
Possible to set up catalytic upgradation/separation to Jet Fuels and to Industrial Oils viz. TURBINE Oil,Transformer Oil.
05/12/2008 1:05 AM
Thank you
Jet full will need lots of quantities.
Industrial oils maybe the quantity I have maybe is good for that, and the supply is continued.
give more info on what type of (small scale)plant is needed to convert to industrial oils.
any other products can be made of diesel?? please advice
10/01/2011 2:24 AM
small scale supply of diesel fuel , i mean truck loads
any products that can be made from diesel any chemical products that diesel is the main in product
Please advice
05/12/2008 9:49 AM
Its a very good terrorist explosive when added to a few other simple components....
But that may not be quite what you meant, sorry!!!
05/12/2008 12:17 PM
Horsepower
ONE TEST IS WORTH A THOUSAND EXPERT OPINIONS
Andy Germany (1); erssk (1); MUKULMAHANT (1); tarik (2)
You might be interested in: Fuel Testers, Fuel Cells, Fuel Additives
