Previous in Forum: ducts and pipes   Next in Forum: gear cutting
10 comments
High RPM Tachometer
05/16/2008 11:29 PM
I am looking to find a direct coupled tach that reads in the range of 7000 to 13000 RPM to be used on a motor test stand. The motors to be tested are 28vdc. The tach needs an accuracy of +/- 5%. Sorry, strobes will not work due to different test motor configurations. Does anyone know of a web based or US supplier?
"If you need a machine and don't buy it, then you will ultimately find you have paid for it but don't have it" - Henry Ford. (Also my excuse when adding to my ever expanding collection of tools)
Re: High RPM Tachometer
05/17/2008 6:06 AM
An incremental encoder could be used. One from the DRS61 range from Erwin Sick can be programmed for 60 pulses per rev. All you need to do is connect a frequency meter (or a DVM with frequency measurement range) for a read-out in rpm.
Alternatively, a toothed wheel with 60 teeth & a magnetic proximity sensor (or slotted disk used as a photo-interrupter) would do the same thing.
05/17/2008 10:59 AM
Look on ebay you will find plenty of the hand held tacho's available which come with rubber conical ends or with rubber wheels to press on to rotating shafts to measure rpm. They are accurate and last a lifetime without using batteries, because they don't use the modern digital electronics they also are cheap on ebay!!
John.
Canada - Member - New Member
Good Answers: 11
05/18/2008 12:08 AM
A 60 tooth gear with a magnetic pickup will give you Hz equivalent to RPM on a frequency counter.
Good Answers: 19
05/18/2008 12:38 AM
http://www.monarchserver.com was offline Saturday evening (5/17/08).
This reseller's page gives you a look at some of their products.
http://www.directindustry.com/prod/monarch-instrument/portable-tachometer-7418-182526.html
Good luck.
05/18/2008 10:03 PM
Try a motorbike Tachometer, an instrument maker can make you an attachment to connect to your motor shaft(s), I suggest you fix the outer case in line with the shaft and attach the drive cable by rare earthy magnet + rubber
05/19/2008 8:31 AM
McMaster Carr has several that will read these speeds.
05/19/2008 6:17 PM
Avi-tech,
Google Hall Effect transducers.
Or try infra-Red/Laser hand held. Are you in the P-82 repair business?
Wangito.
Never trade luck for skill.
05/20/2008 10:10 AM
No, I work on Bell Helicopters. I like P-51s and unusual aircraft so I thought what a great combination of two interests. Not very many people know of the P-82.
Thanks for the comment,
Dave
Good Answers: 12
05/20/2008 9:22 PM
I always wondered about that critter... I assume it had a crew of 2... and what if each one wanted to go in a different direction?? Did they have flight controls in both cockpits? Did each pilot have control over his own engine? I assume the two sticks were tied together (if there were two). I don't even want to think about doing a controlled turn with one pilot on one aileron and the other pilot on the other... Does anyone have any info on this siamese twin??
Bill
05/21/2008 1:20 AM
Yes it had 2 pilots, one on each side but the controls were linked as any other aircraft was and I assume had only one pilot in command. Later versions replaced one pilot with a navigator. What I would like to know is what the pilots went through to fly so far off centerline. I am sure even routine maneuvers such as banking probably put them through quite a roller coaster of a ride, let alone high G combat maneuvers.
Register to Reply 10 comments
Anonymous Poster (2); avi-tech (2); bubbapebi (1); Electroman (1); gigaconcept.com (1); JohnDG (1); Sciesis2 (1); wangito (1)
