Previous in Forum: electrical construction   Next in Forum: details for power transformer deffrential stability test
Reverse Power relay
05/18/2008 12:08 AM
For reverse power relay current and voltage to be sensed by the relay. Current in whioch phase and voltage between which phases are to be connected to relay.
Then for reverse reactive power relay current and volage of which phases are to be connected.
Good Answers: 230
Re: Reverse Power relay
05/18/2008 12:18 AM
Hello nambiathiri
Is this a class or homework answer?
A please or thank you is generally a good way for a prompt answer.
Reply with
Kind Regards....
Good Answers: 80
05/19/2008 11:10 AM
Sparkstation, are you in a "reform the world" mood today? You are right, people are often rude. Thank you for teaching them good manners. Hopefully they will get the message. Good job.
05/18/2008 9:48 PM
That will depend on the manufacturers specifications. Look at www.time-mark.com. They are one manufacturer. They have diagrams and brief descriptions of their products. It should answer all your questions.
Good luck,
James
" adapt, improvise, overcome "
05/19/2008 8:05 AM
Try GE they are the industry standard for protective relaying http://www.geindustrial.com/cwc/Dispatcher?REQUEST=PRODUCTS&pnlid=6&famid=31&catid=229&id=ggp
05/21/2008 1:17 AM
see any wiring diagram of a panel for yourself. Then ask for nay doubts
Best Regards, Shivaram
Anonymous Poster (1); hastingselectric (1); marcot (1); shivaganti (1); Sparkstation (1)
