Previous in Forum: Pressure Rating   Next in Forum: piping engineering- pressure temperature rating
Canada - Member - New Member
Ball Valves
05/18/2008 7:15 AM
For Ball Valves:
What is the definition of short pattern and long pattern ball valves?
For trunion mounted ball valves are there short and long patterns?
Re: Ball Valves
05/19/2008 12:53 AM
Ball Valve
Ball valves usually function as block valves or isolation valves to fully shut off or fully open flow. It is suited for conditions where quick on/off and /or bubble tight service is required.
Note:
1. Soft seated ball valves shall not be used welded because the welding heat will damage the seat.
2. Soft seated ball valves have lower pressure/temperature ratings as compared to same class metal seated ball valves.
3. Soft seated ball valves shall not be used for throttling service because the soft seat might be damaged due to erosion during the throttling operation.
Types of Body
a.
Multi-piece Body: As shown below, this design is easy to maintain, but it is generally recommended for utility services. In order to use this for hydrocarbon service, the design must be certified for "firesafe".
b. One-piece Body: There are three basic one-piece designs: the end entry, top entry and sealed (welded) designs. The top entry design is a preferred design due to ease of inline maintenance.
Types of Seat Rings
a. Metal to Metal: These are generally not bubble tight and are used for temperature over 400F.
b. Soft Seat (Metallic Seat Ring): The metallic seat ring, containing nonmetallic insert, usually requires spring force to achieve tight seal. Due to springs, this design is not used in corrosive service.
c. Soft Seat (Nonmetallic Seat Ring): The nonmetallic seat ring is made from e.g. Teflon. The ring is held against the ball by an insert. For firesafe service, a secondary metal to metal seating arrangement is required to omit leakage in the event that the soft seat material is lost during a fire. This is done by adding a metal retention lip as shown in figure.
Ball Supports
a. Seat Supported: In this design the ball is supported by the seat rings. The seat rings are fixed in the body and the ball is free to move. Therefore, only one seat seals at a time and the valve can not be considered a " double block and bleed" type. This type of valve is used for sizes smaller than 6".
b.Trunnion Supported: In this type the seats are spring loaded and floating while the ball's position is fixed. The valve is capable of sealing from both sides, and is therefore also called block and bleed type valve. All ball valves 6" and larger in Classes 150 and 300, and all sizes in Class 600 and higher shall be this type.
Re: Ball Valves
05/19/2008 7:03 AM
Many thanks for responding but you dident answer the questions.
Re: Ball Valves
05/19/2008 8:11 AM
"Pattern"?
Short spindle would be general purpose.
Long spindle would be needed to mount the actuator clear of any insulation.
Re: Ball Valves
05/19/2008 9:31 PM
Many thanks for the respose but you dident answer the questions.
Re: Ball Valves
05/19/2008 9:12 AM
The face to face dimension (length from one flange to the other) is shorter in the short form compared to the other
If you don't know where you are going,you are bound to get there
Good Answers: 123
Re: Ball Valves
05/20/2008 7:57 AM
I am not familiar with the term long\short pattern with respect to ball valves. Tyco does offer long and short bonnets for ball valves used on cryogenic applications. Try looking at www.tycoflowcontrol.com. Good luck.
Bob
Good Answers: 61
Re: Ball Valves
05/20/2008 9:52 AM
chama2633,
It might help us to offer answers if you would share a little more information:
What is the origin of this question?
Where did you see it or hear it?
Define the general situation where this would apply.
Do it once and do it right
Register to Reply 7 comments
bob c (1); chama2633 (2); Fulan (1); PennPiper (1); PWSlack (1); srini (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
