Previous in Forum: Ball Valves   Next in Forum: hydraulic test stand repair needed
piping engineering- pressure temperature rating
05/19/2008 2:16 AM
how we calculate pressure temperature rating for piping element? explain with an example.
Re: piping engineering- pressure temperature rating
05/19/2008 7:05 AM
In my opinion, we should first tabulate the operaating/design temp and pressures of all the lines in the system. The worst combination is used to choose the rating from the pr-temp rating tables given in ASME B16.5 for flanges. eg if the worst presure in your system falls in the table for 150# in ASME B16.5, the rating of your syste m is 150 or else go hiegher.
05/19/2008 10:29 AM
Calculate?
Normally this information is tabulated, and just needs looking up in the appropriate reference standard at selection time.
Reinvention of the proverbial wheel is rarely necessary.
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
09/05/2008 2:33 AM
There are a lot of standards. Just look to apropriate for your service.
Look over to the next challenge
Nithya Iyer (1); PWSlack (1); user-deleted-1104 (1)
