Previous in Forum: hydraulic test stand repair needed   Next in Forum: Pressure gauge filled with extra glycerin for horizontal mounting
Auto drain trap
05/19/2008 9:07 AM
Can you tell me thw working principle of auto drain trap?
Is it working in mechanical mode or timerbased mode?
Re: Auto drain trap
05/19/2008 10:12 AM
Q1: <...Can you tell me thw working principle of auto drain trap?...>
A1: It works by the presence of liquid operating a mechanism that expels that liquid from the system.
Q2: <...Is it working in mechanical mode or timerbased mode?...>
A2: Without posting a photograph, it is impossible to tell.
Re: Auto drain trap
05/19/2008 11:00 AM
it is based on same mechanism of filling toilet flash water tank. it has arm with buoy which cause evacuation when the fluid level become high.
Good Answers: 101
Re: Auto drain trap
05/19/2008 10:23 PM
Usually it's a simple floatation device. When the water level is high enough, the float rises, opening the valve to drain the trap.
Re: Auto drain trap
05/30/2008 2:33 AM
Sorry where this auto trap can be used? is there any special application?
ahmedalqassab (1); DVader1000 (1); eyal g (1); PWSlack (1)
