Previous in Forum: Satellite Phones in Mexico   Next in Forum: chip
11 comments
Fan Voltage Regulator
05/21/2008 1:16 AM
A warm Hi 2 everybody!
Pls let this novice player know that : can general electronic fan voltage regulator (used for 230V AC) be used for 24 volt dc control? or some modification is required?
Thanks & regards!
Re: Fan Voltage regulator
05/21/2008 3:07 AM
Does it need to be galvanically isolated from the incoming mains for safety reasons? If so then there are plenty of lumps of equipment available in the Maplin, Farnell and RS catalogues (usual disclaimer), and inexpensively too.
Good Answers: 230
05/21/2008 5:05 AM
Hello fireball
The simple answer is: Yes, but the modifications would cost much more than buying a electronic fan voltage regulator made for 24 volt dc control.
Take the advice from PWSlack above, and get one for the correct voltage.
Kind Regards....
Re: Fan Voltage Regulator
05/22/2008 5:35 AM
Hi, you know that things meant for ac may or may not be directly used on DC voltage.
Fan regulator consists of resistive element with a knob that can be placed manually at different position of that resistor to vary the resistance.
AC voltage is used in driving the fan rotor, that consists of its own resistance & fan regulator is nothing but resistance that is used to vary the resistance of rotor which in turn changes the speed of the rotor. So fan regulator is just an additional resistor used in parallel or series with rotor to change the rotational speed of fan.
A fan regulator can be used for 24V dc control only if its internal resistance can bear that much DC voltage & heat due to continuous operation on 24V. So the thing that you can do is : test the regulator on dc voltage of 24 volt, if it works properly then it can surely be used to control 24V dc voltage.
Necessity is the mother of invention, no matter whether need is yours or anybody else.
Good Answers: 230
05/22/2008 6:43 AM
Hello Deepti Saini
fireball has not advised us of the type of regulator he possesses, except: <"....general electronic fan voltage regulator (used for 230V AC)....">, without a specific make/model etc.
fireball has also not advised of the type of motor in his proposed DC fan, except it is 24 Volt.
Thus nobody may properly advise fireball because insufficient information has been provide to make a correct reply.
Your statement: <"....Fan regulator consists of resistive element with a knob that can be placed manually at different position of that resistor to vary the resistance...."> is not necessarily true, as there are other types of fan speed controllers, and fireball has stated the one he has is : <"....general electronic fan voltage regulator (used for 230V AC)...."> which is not the resistive type you mention.
That's why PWSlack and myself gave the replies as above.
I trust you appreciate why I reply to your Post.
kind Regards....
05/23/2008 6:42 AM
Hello Sparkstation,
As now Fireball has already mentioned, I also wanted to tell you that he didn't describe at all about any "24V dc fan" that you were assuming fireball want to control. And one more thing I just want to tell you that a general electonic fan voltage regulator is always made of a simple resistor whose knob controls the voltage to fan, & for any other electronic fan voltage regulator, specification of type of model is required.
Now leaving all these issues I think we should try to provide the solution to SCR controlled Fan voltage regulator mentioned now by Fireball.
Good Answers: 230
05/23/2008 8:10 PM
Hello Deepti Saini
<"....And one more thing I just want to tell you that a general electonic fan voltage regulator is always made of a simple resistor whose knob controls the voltage to fan, & for any other electronic fan voltage regulator, specification of type of model is required....">
I don't really wish to contradict you, but you are quite incorrect in that statement.
if you intend to give electrical or other advice to others, please ensure you state the correct facts.
There are many "general" ways of controlling the fan speed electronically, other than with a simple potentiometer (<"....variable resistor whose knob.....">)
However, I do realise that in your location, and in your experience, you may have never seen any other type of fan speed controller.
Kind Regards....
05/22/2008 11:05 AM
Hi did you notice , he meant Electronic Fan speed regulator !
05/23/2008 12:58 AM
Yeh I have noticed that, General Electronic Fan Voltage Regulator is the device which actuallly controls the speed of fan by regulating the votage.
05/23/2008 6:01 AM
Hi !
Sorry for misconceptualize!
I mean an electronic fan voltage regulator which may be consist of SCRs or like(i don't know exactly).
and i wish to control a 3.3 volt LED supplied with 24v dc.
Does it possibe with electronic fan regulator?
Thanks & regards!
05/24/2008 9:12 AM
Hi agian!
I probably got the answer.
SCR and TRIACs remains ON after it gets fired once by its gate terminal.
So it can not be worked to control DC supply to the load using general fan regulator ciruit.
Thanks for all the interestive response!
06/15/2008 1:29 PM
Dear Friend !
The Fan Regulator available in market for used for 230V or 110V AC uses a Triac & the Regulating Control is a variable Resistor & is the part of Triac's Control-Voltage to fire @ varying angles. [A capacitor in series with the variable Resistor ]. Gate Pulses on each 1/2 cycle for Triac.
In a DC Cct it cannot generate varying voltage for control of Triac's angle of fire.
Kind regards !!!!!
Register to Reply 11 comments
Anonymous Poster (1); Deepti Saini (3); fireball (2); Haajee (1); PWSlack (1); Sparkstation (3)
