Previous in Forum: MCCB Schematics   Next in Forum: Conversion of Voltage of Frequency
load flow calculation
05/21/2008 4:43 AM
how to calculate the load flow claculation and example for panels and other calculations
Good Answers: 230
Re: load flow calculation
05/21/2008 4:51 AM
Hello Guest,
Is this a class or homework Question?
Please reply, with
Kind Regards....
05/23/2008 4:31 AM
Hello sir
Thanks for your feedback,i need how calculate sizing of panel
Good Answers: 230
05/23/2008 4:56 AM
Hello Guest,
You need to advise some specifics:
  1. Supply Voltage
  2. PSC at Supply point
  3. Mains Supply Cable - Size and type
  4. MVA short Circuit Current (PSC) of switchboard
  5. Single Phase
  6. 3 Phase
  7. DC
  8. Frequency in Hz
  9. Load Current
  10. Power Factor at Main Switchboard
  11. IP Rating of Main Switchboard
  12. Other relevant - Advise please
Location - Climate:
  1. Antarctica
  2. Sahara
  3. Monsoonal
  4. Annual Max - Min Temperature
  5. Annual Max - Min Humidity
  6. Other - please advise
Jurisdiction:
  1. Europe
  2. US
  3. Dubai
  4. Australia
  5. Argentina
  6. Canada
  7. Other - Please advise
Load:
  1. Steel Works - Advise annual tonnage
  2. Cement Works - Advise annual tonnage
  3. Foundry
  4. Electrolytic Plating Works
  5. Harbour Works
  6. Hospital
  7. Jewellers shop
  8. House
  9. Home Workshop
  10. Other - Please advise
The above are a few of the needed informations.
There are further specifics needed, but those will do for a start.
As you can see, if your Question is extremely general, it becomes almost impossible to answer.
Once the scope of the Question is narrowed, with specifics, then a proper answer may be obtained.
Reply here, with
Kind Regards....
01/03/2023 9:32 AM
It depends upon what is in it; the information has been withheld from the forum.
Anonymous Poster (1); PWSlack (1); Sparkstation (2)
