Previous in Forum: SEER Calculation   Next in Forum: pressure vessel design procedure
Vacuum Pipe Sizing
05/24/2008 11:16 PM
We are currently designing vacuum pipe system for a 50Hp vacuum pump. However we are faced with problem on the correct size of vacuum pipes both for the headers and distribution piping system. Where can I get the table for the correct vacuum pipe size for the equivalent vacuum flow and pressure. Thanks.
Good Answers: 19
Re: Vacuum Pipe Sizing
05/25/2008 2:58 AM
Doesn't the vacuum pump sales rep have a chart? I bought 3-25 hp rotary screw vacuum pumps and the installation book we got had a chart based on CFM and vacuum loss per distance.
Good Answers: 109
05/26/2008 3:20 AM
Any book on vacuum technology has the data.
To know the HP is not sufficient, you need the pressure too.
Tube sizing is very different according to physics of flow: viscous, Knudsen, molecular?
RHABE
05/26/2008 9:19 PM
As others have said, you have to know the flow rate, fluid, and pressure. Vac pump HP is not the right starting point. ONce you know the above, compressible pressure drop calculations from 10 Torr and higher conform to classical calculations. You probably can use traditional calculations down to 3 Torr without significant error. Given such a high HP pump, I doubt you're working below those pressures. Best wishes.
05/27/2008 11:26 AM
Thanks to the feedback. Further to that , I have the data corresponding to the flow and vacuum pressure. Each 50HP pump is around 730 cfm with operating vacuum pressure of 28" Hg. However, I know what vacuum pipe size is proportional to the flow and vacuum pressure. What i mean is the chart that shows equivalent pipe size corresponding to the flow and pressure loss.
Good Answers: 19
05/27/2008 11:28 PM
Google "vacuum pipe sizing", you should get 235,000 threads to check out.
01/03/2013 4:26 AM
Dear Friend,
Your message is not containing the data like, quantity to be handled, vaccuum, density of the medium to be handled etc.
It is very simple. first decide the quantity and vaccuum, to be obtained. There are standards for the velocity for different materials, an it may vary from 3.0 Metres/Sec. to 30 Metres/sec.
Then you can size the piping and calculate power required.
Thanks,
DHAYANANDHAN.S
airmek (1); Anonymous Poster (1); dhayanandhan (1); RHABE (1); Ried (2)
