Previous in Forum: Buying and Installing a Load Meter   Next in Forum: Calibrating a Sand Hourglass
18 comments
United Kingdom - Member - New Member Engineering Fields - Energy Engineering - New Member Engineering Fields - Piping Design Engineering - New Member Fans of Old Computers - Commodore 64 - New Member Technical Fields - Technical Writing - New Member
Wanted: Low-Power DC Pump for Vegetable Oil
06/10/2008 11:11 AM
Hi folks,
I have a new pumping requirement, and after muddling through umpteen google pages, I have found nothing suitable. I am looking for a low power 24V DC pump that can deliver up to 5L/min of vegetable oil (100 deg C) preferably at a variable rate. In normal operation it is pulling oil up from a depth of less than 1m and delivering to a tank at ground level. There may however be scope to mount the pump at oil level and pump one metre up to the tank. The pump will be running from a battery and so low power is a priority. I am hoping to find something that can do the duty using less than 20W.
Thanks for the help.
Des-Eng
Those who believe in telekinetics, raise my hand - Kurt Vonnegut
Pathfinder Tags: low power dc oil pump
Re: Low Power DC Pumping (HELP)
06/10/2008 11:21 AM
Hmmm. 20 watts 5 L/m is going to be tough.
Shurflow pumps take a lot more than that. We do a peristaltic which will do 1 L/m at about 12-15w. (we do have some 24v motor/gearbox aassys too although they are non standard.)
What sort of duty cycle are you after? A peristaltic won't want to run continuous, say a few hours a day would be ok, else you will be constantly changing the squeeze tube.
Can you put up with a slower delivery?
06/10/2008 11:39 AM
Hi Del,
Thanks for the quick response. The duty is likely to be about 8-10 hours/day intermittent operation with the pump turned off overnight. I was hoping to find a pump that didn't need regular servicing. Up to 30W would be OK, and down to 4/L a min could also be acceptable, but these are the max/min limits.
DE
06/10/2008 5:17 PM
Seko have a presence in UK they do good diaphragm metering pumps but I think they are mains driven...they will run ad nauseum tho' and are accurate and easy to set up.
Or maybe shurflow.... they do DC stuff but it's quite high current.
I'd rule out peristaltic on duty cycle/tube life grounds.
06/10/2008 11:21 PM
Automotive fuel pumps are what you need, they are cheap and reliable. they use very little current if you are not lifting far and at nil pressure. They are also designed for continuous running. You can either get 24v or 2x12v in parallel
06/11/2008 2:34 AM
But they won't pump 5L/min I wouldn't think!!!
06/11/2008 8:08 AM
don't pump liters then pump gallons.
06/11/2008 8:06 AM
WAIT!
Now if it needs to run 8/10 hours that means while your pumping the tank is being filled? right.
If so. run the oil straight into the tank your filling.
can you use a
SHURflo 24 Volt Submersible
06/10/2008 11:23 AM
A peristaltic pump might work, though the temperature spec is going to make the tubing choice a tricky one.
Watson Marlow (usual disclaimer)?
What peristaltic pumps manufacturers are used in blood and dialysis applications?
Re: Wanted: Low-Power DC Pump for Vegetable Oil
06/10/2008 10:54 PM
You may wish to search "metering pump" or "acid pump" which is what we used them for. I think they were 115VAC which a UPS and ground fault outlet can create.
Years ago Grundfos made Stainless HVAC circulating pumps for boiler systems, various flow and head capacities.
You may also wish to look at a boat bilge pump, which will run on 24 VDC.
Or a diesel engine may use a fuel pump that is 24VDC and low quantity.
"I believe we are masters of our lives - we hold all the cards and it is up to us to use them right." Vesna Vulova - survived 33,000ft fall
06/11/2008 5:33 AM
http://flow-control.globalspec.com/SpecSearch/PartSpecs?PartId=%7BB6669673-1BF0-4D17-9965-14C564B34B45%7D&VID=134989&Comp=3943&QID=11099756
http://www.clarksol.com/html/prodspecsM3000Pump.htm
It looks a bit difficult to meet your 20W requirement, which seems a bit strange as you're actual (output) work rate is less than a Watt. I suspect that most pumps in this category would push the liquid up much more than a meter.
Not sure if this :- http://www.clarksol.com/html/prodspecsEMX08Pump.cfm
With a DC adapter board:- PD-106 DC
meets your other requirements; could be worth ringing them.
I'm very suspicious of the fact that they seem to be selling a diode which is part of the electrical design separately.
06/11/2008 5:48 AM
I think I'd be tempted to replace that 3 Amp diode:-
http://cpc.farnell.com/SC05622/components-spares/product.us0?sku=multicomp-1n5406
with a 6 Amp one:-
http://cpc.farnell.com/SC05939/components-spares/product.us0?sku=multicomp-p600k
Perhaps I'm just reading something into their "price list" which isn't there .
06/11/2008 7:47 AM
Hi Randall,
Thanks for thie input.
The M3000 range looks a bit too big and consumes 100W on DC.
The EMX08 looked more promising, but unfortunately it can't take the temperature.
Thanks again for your suggestions.
DE
06/11/2008 7:50 AM
Anyone know who changed the title of this thread.
It used to read "Low Power DC Pumping (HELP)", but now reads "Wanted: Low-Power DC Pump for Vegetable Oil". Do the site moderators get involved in the naming of threads ?
DE
06/11/2008 7:59 AM
06/11/2008 8:13 AM
Hi DW5B,
Unfortunately the flow rates for these pumps are much higher than the rate I require. The main focus of the requirement is acheiving the duty with minimal power.
DE
06/11/2008 8:21 AM
I was told once if the problem is taking more time to solve that is should CHANGE THE PROBLEM.
I would made a change that would adapt one of the affordable pumps to needs.
Good Answers: 150
06/11/2008 9:13 AM
maybe this puppy would fill the bill.
http://www.pumpbiz.com/products/index.cfm?fuseaction=pump_model_detail&product_id=6206&series_id=296
24V 10W 3 gpm TDH 4ft, the only question mark is the silicone elastomer. Not sure if that is compatible with Veg. oil. but I'm sure that March can make a version with Viton seals if you contact the manufacturer directly.
Who is John Galt?
Good Answers: 19
06/11/2008 10:30 AM
Can ask you to look up condensate power pump Model APT of Spirax Sacro or the one with an ss body to pump this 100C vegetable oil but only with air/steam as motive. Very low in energy and virtually maintenance free. Will pump when there is something to pump.
Register to Reply 18 comments
Anonymous Poster (1); CoronaCameraMan (1); dadw5boys (4); design-engineer (4); ducon (1); PWSlack (1); Randall (2); Rorschach (1); user-deleted-1105 (3)
