Road Map to Phase Out CFCs in Middle East Countries
06/10/2008 2:53 PM
I AM IN THE PROCESS OF COMPILING A DOCUMENT TO PREPARE A ROAD MAP TO PHASE OUT CFCS IN MIDDLE EAST COUNTRIES. REQUEST SEND VALUABLE INFORMATION TO MY E MAIL ID mrswamy@omantel.net.om
Re: ROAD MAP TO PHASE OUT CFCS IN MIDDLE EAST COUNTRIES
06/10/2008 3:09 PM
I hope your caps lock works on your keyboard and you don't have to use upper case for the whole document!
Actually, it's bad form to use only capital letters when you write (unless it is a legal document). People take it as if you shouting or commanding people to do things.
Sorry, I don't have information to send to you. Good luck with your paper!
06/12/2008 3:52 PM
There are a large number of old machines usoing older, "non-environmental" refrigerants. It is impossible to replace all systems at once, so the international community is allowing a phase-out plan that will take a few decades to full implementation.
If the machine does not leak, it is not a problem. When a machine is replace, the old refrigerant is recycled for use in other old equipment. At some point 15-20 years from now most of the world will have the old equipment replaced with "clean" refrigerants.
try to Google "Montreal Protocol", these sources should give the answer you seek. Although the banned refrigerants are not in production, recycled refrigerants are in use and cost is based on supply and demand. As supply shrinks and demand rises, people will change to newer equipment.
