Previous in Forum: ship inside the bottle   Next in Forum: Cheap Conductive Adhesive
automation of a lathe
06/11/2008 8:48 AM
hello friends...how to automate an lathe....i want a clear answer...this is sakthi...an indian...thanks for ur reply...
Also posted in: also posted in Transportation
Re: automation of a lathe
06/11/2008 12:17 PM
"how to automate an lathe....i want a clear answer"
There can be no clear answer unless the QUESTION IS CLEAR!!!!!
Bud Trinkel
Good Answers: 97
06/11/2008 12:17 PM
Step 1 would be to replace two hand wheels (travel and depth) with stepper motors. For that you would need a driver. Gecko makes nice stepper motor drivers. The Gecko can then be driven by using data lines of the parallel printer port. For driving the port a program like Mach_3 works well. You will further require a CAD packet.
A better solution is to use servos instead of steppers.
For further automation like auto feeding, auto setup, auto tool change more improvisation would be needed.
Good Answers: 97
06/11/2008 1:53 PM
You also get steppers already fitted with the driver. All that is the required is a power supply and 2 wires from the port.
You can look at http://www.machsupport.com/ for the program.
I suggest you surf for "stepper motors" and "stepper motor drivers"
06/11/2008 4:01 PM
Check out this thread! Start reading at about post #10 by Masu!
Good Answers: 16
06/11/2008 11:42 PM
I do not mean to sound like a wiseacre, but the best way to automate a manual lathe is to leave it alone and purchase a small CNC lathe. That is, in my opinion, a clear answer to an ambiguous question.
Best Regards,
Ing. Robert Forbus
"Yeah, but will it fit?"
06/12/2008 4:53 AM
stepper motors instead of hand wheels,encoders for positon sensing,limiting switches,load of circuitry and once your done with that and hooked up to a computer,the right software.
i've tried this already,thats assuming your trying what i think you'r trying.your question is very unclear and it would be impossile to answer in such a short manner even if you were clear.heres some clear advice 'dont waste your time'
or try www.cnczone.com ,these guys were a great help.
pineapples hate me.its ok i dont fancy thm that much anyway.
BudT (1); Hendrik (2); Ing. Robert Forbus (1); Mr. Truman Brain (1); shanky1367 (1)
