Previous in Forum: Looking for small air/fluid manifold...   Next in Forum: Bluetooth head phone help!
OLTC
06/22/2008 5:06 AM
Hi All,
1.Why people are scared of operating the on load tap chager?
2.What needs to be done to allay fears?
Plz let me know your perception
vs rathore
Good Answers: 230
Re: OLTC
06/22/2008 2:22 PM
Hello vs rathore
Are these Class or Homework Questions?
I'm not afraid of operating on-load tap-changers.
These automatically work many times each day, in their hundreds of millions of installations, right around the world, without any bother at all.
Reply with
Kind Regards....
Good Answers: 50
Re: OLTC
06/23/2008 3:45 AM
Is he talking about Ungbang, the god of load tap chagers versus Rathore, the god of imaculate grounding?! Woof!!! If so, my money is on Unbang!!!
I'll be down in my bunker until this all blows over!!!
Re: OLTC
06/23/2008 3:57 PM
If you are refering to changing a tap on a transformer to adjust for variations, there is good cause for fear.
If one gets lucky and switches at or near 0 volts, not much happens. However, if the circuit is broken at peak voltage, arc flash can be second only to a lightning bolt striking in intensity and devastation.
If there are electronic controls and switching behind adequate sheilding, there is not much to fear as the switch will occur at 0 volts.
More info is need to properly assess your particular question.
Bill H.
Register to Reply 3 comments
Bill H. (1); Sparkstation (1); vermin (1)
You might be interested in: Taps, Bus Plugs, Guides Bushings and Drill Bushings
