Previous in Forum: Vibration in Cane Juice Pump Line   Next in Forum: Hydraulic Calculations
Calculating the total surface area of insulation on pipe
06/24/2008 1:57 PM
How do I calculate the total surface area of insulation on pipes?
Re: Calculating the total surface area of insulation on pipe
06/24/2008 5:57 PM
Multiply outside diameter of insulation by itself X Pi/4 X length of the pipe.
Area = (O.D.) X (O.D.) X Pi/4 X L.
Good Answers: 19
06/27/2008 10:52 AM
Suppose :
4" pipe + 4" insulation = 4 + 4 + 4 = 12" x 3.142/12 = 3.142 sft x total length of pipe = Total Sft.
6" pipe + 4" insulation = 6 + 4 + 4 = 14" x 3.142/12 = 3.67 sft x total length of pipe = Total Sft.
6" pipe + 2" insulation = 6 + 2 + 2= 10" x 3.142/12 = 2.62 sft x total length of pipe = Total Sft.
06/27/2008 2:56 PM
ducon Disregard Post #1. SS
The Diameter of the 4" pipe + 4" of insulation is 12" or 1.'
The Circumference of the 1' diamenter is therefore C = Pi X D = 3.14159 ft.
or simply 3.1459 Sq.Ft. per Ft. of length of pipe.
My apologies for prior erroneous figures.
Good Answers: 19
06/28/2008 12:36 AM
Thanks Stirling Stan . No apology required.
I just gave the same lay-man formula I give to my workers since easier to calculate & understand. Further simplified as : 4+4+4 x .26= Sft. x total length in Rft. = Total Sft
10/28/2016 11:54 AM
Dear sir, i am new to insulations Field so please guide me .How can i measure the surface area of a pipe section for example: NB is 4 inches n thickness is 25 mm.considering 1 linear meter of pipe.
Also i want to do insulations to a pump,its dimension is 0.8m×1.2m ,while the insulations thickness is 25mm.. ?
Good Answers: 19
10/29/2016 11:38 PM
For Pipes: 4" dia x 1 metre(3'-3") with 1" insulation
4 +1+1 = 6 x 3.142/12=1.6 Sft x 3.3 =5.2 Sft
For Pipes: 4" dia x 1 metre(3'-3") with 4" insulation
4 +4+4= 12 x 3.142/12=3.14 Sft x 3.3 =10.4 Sft
For Flange/Valve Boxes we take a lump sum amount per sizes x Qty.
Why? Because the time it takes to fabricate these boxes does not justify running Sft rates.
02/02/2021 2:45 AM
Commercial pipe insulation is sold by unit length for a given diameter. The calculation, while simple as indicated above, is usually unnecessary.
ducon (3); Pravish mohan (1); PWSlack (1); Stirling Stan (2)
