Hi to all those who are taking the time to read this,
I'm new to this site, so sorry if I ask too much or too little.
Anyway here goes, I am currently evolving a project for an Engineering HNC.
My design is a torque wrench that is curved at the top by 90 degrees and has a hydraulic core that eliminates the use of a lengthy spring along its body! This wrench is hand held and hand driven and to be used on aircraft.
So, my problem: I cannot find a solution to working out the internal pressure that will be felt on the inner walls of the wrench caused by the fluid when under 'compression' from the spring pressure and the torque created by a bolt during rotation (tightening)?
Again sorry if I have given too much, too little or even the wrong type of question for this site.
Regards
Samurai7
