Previous in Forum: Electric Motorcycle   Next in Forum: Transportation Songs
Fanuc spindle drive
06/26/2008 10:08 AM
I am facing a problem with my fanuc make spindle drive. It is blowing fuses and transistor module of braking ckt. almost in every 2-3 months duration, everything looks fine.
I have checked the firing pulses it is also ok. what to do next?
I have replaced the resistors also.
Re: Fanuc spindle drive
06/27/2008 10:44 AM
It helps to know more specifics about the drive/motor package, but I have some general ideas.
if this an analog or digital system? PWM or SCR type?
In both cases, look at deceleration rates. Decel rates are adjusted in the drive firmware or Executive system for digital systems and by potentiometers on analog systems. If the system is having to dump a lot of back EMF (generated by shorting the windings with the transistors you mention that go out), the power has to be dissipated in the transistor/resistor circuit. By spreading the decel rate over a longer period of time, the maximum rating is less likely to be exceeded. If the decel rate cannot be modified, use a transistor with a higher power dissipation rating. Make sure the heat-sinking is good by using the proper heat sink compound. Depending on the circuit, it may require a electrically conductive compound. (this is most common with SCR type drives not transistor drives.)
Bill H.
Good Answers: 109
06/27/2008 4:27 PM
Hi,
we shot all three H-bridges in the AC motor of a wafer dicing saw by too fast decelerating and creating a very large overvoltage: as the last post states!
May be you have an unintended brake done with this spindle?
RHABE
07/28/2008 11:28 AM
Dear ashutosh,
It seems you are blowing transistor modules at random. Please follow these steps:
1. If you blowing the same set of transistor modules then there is some defect in the
driver area.
2. On the other hand if you blow diff transistor modules then you should focus on the
current feedback modules (Iamp modules on the drive board) Please change them
you will get the result.
all the best.
Prabhu
Register to Reply 3 comments
Anonymous Poster (1); Bill H. (1); RHABE (1)
