Previous in Forum: transformers   Next in Forum: Neutral cable size
Power Consumption
06/30/2008 3:34 AM
Good afternoon, I know my question is a little elementary however I would like to ask your opinion.
How do you represent 3 Phase Power and single phase power on the basis of consumption? what could be the best example so that non-technical people could understand it fully?
Thank you!
Pleasure in the job puts perfection in the work. - Aristotle
Good Answers: 18
Re: Power Consumption
06/30/2008 9:18 AM
Huh?
If you have a three-phase load, and it's 1 HP, then it's still 746 Watts per HP. If you have a single-phase load, and it's 1 HP, then it's still 746 Watts per HP.
If you want to know how many amperes per phase in a three-phase circuit as compared to the phase current in a single-phase circuit for similar loads, then divide Watts by (volts X PF X 1.73).
If you want to know something other than the very little I have told you, then you'll have to be more explicit.
06/30/2008 10:50 AM
Thank you for the enlightenment.
Actually, it was the same explanation I used, unfortunately the higher management could not digest that the 3 phase could be compared with a single phase power with regards to consumption.
So in my frustration, what I showed to them is the cost of installation and the return of investment just to compare the two loads. Luckily it worked.
Thanks again for the re-assurance. have a great day!
Register to Reply 2 comments
