Previous in Forum: GFCI   Next in Forum: Skew Control on Wide Rail Yard Machines
capacitor
07/01/2008 3:57 AM
hi..
i want to ask y we use coupling and bypass capacitor ic cct....simply give me the reason
Re: capacitor
07/01/2008 7:44 AM
The short and simple answer is...
Coupling capacitors are generally used to block DC whiles still allowing and AC signal to pass. Often used at the inputs to AC amplifier stages. DC offsets can be amplified and add up quickly when not blocked out with coupling capacitors. If the DC offset gets too large you will start clipping at the supply rails.
De-coupling capacitors are typically used to short AC signals to ground. They are commonly used at the input power supply pins of ICs. They will both short out some of the AC noise on the power supply lines and they will short the AC noise generated by the IC. If an IC is supplying an AC signal at it's output then it will be drawing AC current at its supply lines. The De-coupling caps keep the AC signal localized to the immediate area and limit the amount that is passed down the supply lines.
Good Answers: 230
Re: capacitor
07/03/2008 6:43 AM
Hello Guest,
from me
Why not Register at Forum, as you have a lot to offer others.
Kind Regards....
You might be interested in: Resistor, Capacitor Networks, IC Modems, IC Timers
