Previous in Forum: Cost-Effective Buoyancy Material   Next in Forum: bronze valves
Equivalent material for 430F
07/04/2008 5:26 AM
Could anyone advice me the equivalent material of 430 F.This is too much cosltly to buy. So i need any ceaper material but have moe or less same properties.
Regards
Re: Equivalent material for 430F
07/04/2008 7:27 AM
For what is 430 F used? Please explain the context.
07/05/2008 12:17 AM
This material used as plunger in the solenoid valve assembly unit.
Regards
07/05/2008 6:52 AM
Does your application require corrosion resistance? 430F is classified as a 'stainless' steel.
If you always do what you've always done, You'll always get what you've always had!
07/06/2008 11:45 PM
Yes our required application is corrosion resistance material.
Regards
07/07/2008 5:24 AM
Could a protective coating fulfill the corrosion requirements?
07/07/2008 11:40 AM
Does the material the plunger is made from have to be metal? Would a high-density plastic do the job, for instance?
Register to Reply 6 comments
Patriotic (2); PWSlack (2); sidevalveguru (2)
