Previous in Forum: ideas about career for feature   Next in Forum: Instrument for measuring Capacitance of Film capacitor
multi phase flowmeter calibration
07/06/2008 7:38 AM
Salamat to all; In my company we have multi phase flow meter for well testing, and now we are looking for the best way calibrate this device, I want to share with you all what is best way to calibrate multiphase flowmeter????
Re: multi phase flowmeter calibration
07/07/2008 4:58 AM
  • Is it measuring mass, or volume?
  • What's in the pipe, at what pressure and temperature?
  • How large is the pipe?
07/07/2008 8:19 AM
* it is measuring volume. *Our fluid represent well outlet(oil+water+gas) with pressure less than 100psi and temperature less than 60 deg C. * 2" pipe diameter.
07/07/2008 9:01 AM
Three phase flow measurement is a speciality item.
Your best bet is to refer to manufacturer's recommendation.
If you don't know where you are going,you are bound to get there
07/07/2008 9:25 AM
Can you just give me the details of the flowmeter, may its manufacturer name and model number so i can search in for some more details.
07/07/2008 11:11 AM
there is no such thing as a multiphase meter. You get estimated flows, you can "calibrate" around a specific mixture and rate, but you cannot get exact flows.
A mass meter will give you excellent total mass flow, but not exact rates of each componet.
contact these people. http://www.ceesi.com/
Mohamedrafi (1); mohand1231982 (1); PWSlack (1); srini (1); vicini (1)
