Previous in Forum: SMS/MMS Texting from the Web   Next in Forum: Conversion efficiency in Power amplifiers....
10 comments
Upgrading HDD
07/09/2008 3:00 AM
Hi there, i had 100gb HDD 4200 RPM, wanted to upgrade to 100gb HDD 7200 RPM is't possible and will not crash my Laptop. any one can help please.
Engineering Fields - Marine Engineering - New Member United Kingdom - Member - New Member Engineering Fields - Mechanical Engineering - New Member
Re: Upgrading HDD
07/09/2008 5:20 AM
Shouldn't crash anything as it is an independent unit. But why not go to a 1 TB?
Reset, Reset
Re: Upgrading HDD
07/09/2008 5:30 AM
if i go to a 1TB HDD, which brand is better performance.
Thank you.
Good Answers: 15
Re: Upgrading HDD
07/09/2008 6:10 AM
Maxtor
If you don't have time to do it right the first time, when are you going to have time to do it over?
Re: Upgrading HDD
07/09/2008 6:13 AM
Any of the well known ones. My preference is for Seagate.
Reset, Reset
Re: Upgrading HDD
07/10/2008 1:11 AM
I think the guys suggesting 1 TB did not notice that you are talking about a laptop. I haven't heard of a TB 2.5" drive yet. I also seriously doubt if you need anything that big as an internal in a laptop, unless your primary function for the laptop is making movies.
Lower density drives of a given vintage are likely to be more reliable than higher density. Any major brand of the same physical size and connection (eg. SATA or PATA) should work.
Re: Upgrading HDD
07/10/2008 2:57 AM
please use is it instead of is't because is't is not a word!
Re: Upgrading HDD
07/10/2008 10:42 AM
Agreed! At first I interpreted is't as isn't, because you can't pronounce is't easily.
Re: Upgrading HDD
07/10/2008 7:15 PM
I believe that very recently a manufacturer started making 7200 2.5" drives, you should take a look around....or use a 3.5" external drive.....
Re: Upgrading HDD
07/11/2008 11:27 AM
4000 rpm drive use less power, 7200 rpm use more. So you're doing an "upgrade" for less battery time?
Pineapple
Re: Upgrading HDD
07/11/2008 6:16 PM
It could well be true, but I feel that a comparison of the two drives needs to be made before that is a known fact......and if the time difference is only minutes over say 2 hours, who would really notice?
So many people ONLY use a laptop on the mains (hopefully either with the battery removed, or they plug the power cord in and out as needed like I do!! Having the battery under charge all the time is not good for it!!) so it might not affect him in any way.....
Register to Reply 10 comments
Andy Germany (2); Andy K (1); charlie_r (1); davah (2); dkwarner (2); Pineapple (1); ronron (1)
