Previous in Forum: ORIFICE PLATE CALCULATION   Next in Forum: what is the different of 304ssl and 316ssl
10 comments
what is the different IDE HDD and SATA HDD
07/10/2008 1:09 AM
what is the different IDE HDD and SATA HDD, any one can help please...
Good Answers: 97
Re: what is the different IDE HDD and SATA HDD
07/10/2008 3:08 AM
IDE = parallel data bus. very limited distance.
SATA = Serial data bus and can be used via USB.
The mechanical parts are essentially the same.
Good Answers: 15
07/10/2008 11:50 PM
ST506 I think was before IDE, 2 cables to the HD interface, and a 3rd (Power)
IDE = Parallel ATA device IDE/PATA -> http://www.faqts.com/knowledge_base/view.phtml/aid/32968
SATA = Serial ATA Device -> http://www.serialata.org/
http://en.wikipedia.org/wiki/Hard_drive
You can also get USB adaptors for IDE drives
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
07/10/2008 5:11 AM
also IDE is slower than SATA,,,
Good Answers: 97
07/10/2008 5:40 AM
It is actually amazing that a single signal wire can be faster than multiple signals.
Where are the days when a Centronix outperformed a RS232?
It has crossed my mind that a 8 or 16 channel serial would be nice.
07/11/2008 8:23 AM
A parallel connection is faster BUT the way the motherboard transfers the information to the drive requires a "token"(clock pulse) passing routine that slows down the parallel interface.
07/11/2008 2:00 PM
its only faster because its newer technology soon you will find the usual multitude of wires
07/11/2008 5:29 PM
HI,
One note: SATA is faster than IDE but also requires it own port type. Make sure you have a sata port on your mainboard. You can buy PCI SATA adapters but I would not recommend it because you can have Interrupt problems depending upon which PCI slots are used and BIOS/Mainboard configuration.
Good Answers: 97
07/13/2008 11:10 AM
bandwidth/$
08/25/2008 4:07 PM
Good Answers: 15
08/29/2008 12:01 AM
Once upon a time, you could pull the card off the drive, and place a card of the competing Interface on the drive and access it that way, I used to do this with SCSI/IDE drives.. cross compile Linux for the HP-RISC system, and load the OS on the disc, remove the IDE Interface and add the SCSI one and plug it into the RISC system, booted up no problems.
Register to Reply 10 comments
Anonymous Poster (1); Apps Man (1); bwire (1); cableIQ (1); ciccio (1); elias_kingdom (1); Hendrik (2); Snaketails (2)
