Previous in Forum: Efficiency of Worm and Bevel Gear Engagement   Next in Forum: Spray Paint Booth Design
11 comments
Measuring Ovals
07/11/2008 10:10 AM
What is the best method or device to accuratly measure an oval?
Pathfinder Tags: radius
Re: measuring ovals
07/11/2008 10:11 AM
Depends on what you need to know. CMM is always good, but do you need location, or length, width, depth?
Re: measuring ovals
07/11/2008 10:30 AM
What do you mean by 'oval'? A rectangle with more-or-less radiused corners (like a running track)? An ellipse? A generalized oval (as per the Wikipedia entry)?
Re: measuring ovals
07/11/2008 10:40 AM
We make radius millwork and are having a lot of trouble making ellipse and oval trim that fits around the windows. I know that there are systems available toa ccuratly measure these and make templates so they fit perfectly, but most are very expensive and I was wondering if anybody had any suggestions on the best way to measure these so they are accurate.
Re: Measuring Ovals
07/11/2008 1:12 PM
An oval what?
Whoops... didn't see #3
Good Answers: 97
Re: Measuring Ovals
07/11/2008 2:37 PM
Hi STICK
You can use a trammels to set out a perfect oval. It can be made from a piece of brandering with 3 x 4" nails. pieces of brandering can also serve as centre line guides.
Google for trammels.
How to fit a oval around a rectangular window using a trammels.
Because it bis possible to fir thousands of ovals you must specify one of the axis.
For example if you choose the minor axis to be x hit 2 nails in the brandering x/2 apart. Now put the drawing nail on the corner and the other nail on the horizontal centre line. the 3rd nail must then be inserted where it crosses the vertical centre line.
Then you are ready to "draw" your oval. (the 2 nails must always be on the respective centre lines)
Best of luck.
Good Answers: 97
Re: Measuring Ovals
07/11/2008 3:01 PM
Re: Measuring Ovals
07/11/2008 6:56 PM
This is OK for a gen-u-ine ellipse, but STICK suggested 'ovals' as well in #3 (see my Wiki link in #2).
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
Re: Measuring Ovals
07/12/2008 10:10 AM
The Best Way = Digitize it into CAD and mill it on a CNC machine.
The most efficient (cost effective) method for your application may require a different (rigged up) approach.
I spent my early years farming so I'm all for "keep it simple - and cheap" but if this is a matter of serious $$ then go high tech and make it happen.
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
Good Answers: 97
Re: Measuring Ovals
07/12/2008 12:40 PM
Oval windows are usually accompanied by a template for making the cutout. You should be able to get a template from the window manufacturer for each type window and then produce a fixture from it. Ya think...
Re: Measuring Ovals
07/14/2008 4:08 AM
What about a thick piece of paper and a pencil. Trace the shape then cut it to make a template.
Re: Measuring Ovals
07/14/2008 10:28 AM
What do you mean by "measure"?
Are you looking for the area? If so, try a planimeter.
Sure, you can touch off edges with a CMM, but if you had a CMM you probably would not be asking the question.
Travis
Register to Reply 11 comments
Anonymous Poster (1); bwire (1); Hendrik (2); JohnDG (2); Labyguy (1); markar (1); Randall (1); STICK (1); user-deleted-1105 (1)
