Previous in Forum: PRS Manager   Next in Forum: Electrical wiring
Caculation for Breaker Capacity Selection for Transformer Incoming and Outgoing
07/16/2008 2:38 AM
I would like to know how to calculate and select Breakers Capacity/rating for the PowerTransformer in coming and Out going.
Transformer details HV 66 KV;LV 11 KV;HV 43.7 Amps,LV262.5 Amps;Impedence 7.17%,Frequency 50Hz.
Good Answers: 19
Re: Caculation for Breaker Capacity Selection for Transformer Incoming and Outgoing
07/16/2008 9:19 AM
What is the fault level?
What is the rating of the transformer?
Already full load current of transformer on primary side and secondary side is available you may have to select the switch gear which can arry the required current and with stand the fault level.Other considerations like temperature,outdoor/indoor ,Vaccuam/SF6 also to be taken into .
Ramesh,Freelance Electrical/automation Consultant
07/02/2010 3:49 AM
Calculation for Breaker capacity selection
07/20/2008 3:57 PM
main points to be known for choosing breaker for incoming and outgoing of transformer are Breaker making and breaking capacity level. for making capacity u all ready given current values usesame only and for breaking capacity find fault current
fault level=1.1*V(line voltage)/(1.7*Z)
where z=impedence of transformer
breaking capacity of transformer should be greater than fault level
07/20/2008 11:30 PM
hi
for that it is very important to have knowledge of rating of transformer and fault level at various point in the system, nomally highest fault level at the terminal of transformer is calculted by Fault MVA = Rating of trans./ % impedance
and from that fault current too,
for 66 kv system you could have SF6 breaker outdoor and for 11 kv, vaccum breaker indoor.
whereas all other parameters of the breakere of 66 and 11 kv are standardised by companies,
regards
divyesh patel
Anonymous Poster (2); Divyesh patel (1); ramvinod (1)
