Previous in Forum: training ....which company to choose for training?   Next in Forum: Writting Etiquite
halfwave rectifier..
07/19/2008 9:52 AM
in half wave rectifier when it is made using diodes the positive part of the signal only got as a output..but when it is made with the opamp the negative part is got as the output..why is it so..is that also a halfwave rectifier as it output,s only half of the signal..
United Kingdom - Member - Member
Re: halfwave rectifier..
07/19/2008 11:50 AM
Your opamp is inverting the output of your rectifier. Easiest fix would be to turn your diode round if a positive output is what you want.
Al
If you remain calm while all those around you are losing their heads, then you haven't realised the seriousness of the situation
07/20/2008 3:51 AM
google precision rectifier
07/20/2008 6:18 AM
Dear Guest,
Not sure if this will help or not but here it is anyway.
http://www.wisc-online.com/objects/index_tj.asp?objID=SSE402
Kind Regards
Mr. W.A. Snow
07/20/2008 10:06 AM
If you want only half wave rectification, you have answers enough, but did you really want full wave rectification?
07/20/2008 3:27 PM
Sounds like your op-amp is set up as an inverting amplifier (hence the negative voltage when you connect your half wave rectifier up to it).
Try looking at Wikipedia or google for basic op-amp circuit principles.
07/20/2008 11:53 PM
I think you needs knowledge about opamps more. Simply search "operational amplifiers" and learn more than you imagine.
Andy Germany (1); Bolton_Alan (1); feridun (1); HoleInTheSnow (1); jack of all trades (1); rcapper (1)
