Previous in Forum: Non woven web thichness inspection   Next in Forum: Sheet Metal Process
8 comments
Exhaust Fan for Bathroom
07/29/2008 6:55 AM
Hi
This is Rajiv, Could u suggest me ,How to decide & Calculate the capacity of Toilet exhaust Fan.
Thanking u
Rajiv Kumar
Re: Exhaust Fan for Bathroom
07/29/2008 7:06 AM
Just select one from the Screwfix catalogue (usual disclaimer).
Good Answers: 266
07/29/2008 7:13 AM
Air change over in the room.
07/29/2008 8:08 AM
It will depend on the regulation by the relevant building authority. For enclosed bathrooms (toilets), it should be mechanical ventilated. Typically it is 10 air change minimum by volume per hour is required, exhaust only, no recycle air. I suggest higher air change if there is lots of lightings especially halogen lamps that will warm up the place.
07/29/2008 3:59 PM
Hello Rajiv,
How big is your toilet? Do you have an outside wall as part of your toilet! Is this your domestic toilet? Would one of these suit your needs?
07/29/2008 11:10 PM
Surely it will depend upon the pungency of the emmissions involved...
07/30/2008 12:06 PM
There are many codes and considerations. 7-10 changes per hour as suggested above is a good guideline. In the US one organization has recommendations The National Kitchen and Bath Association (NKBA). They also consider the area, humidity, and other things.
07/30/2008 1:03 PM
Per table 403.3 in the 2006 International Mechanical Code: 75 CFM per water closet or urinal.
07/31/2008 3:02 PM
Hi Rajiv, Accoding to a local doctor here a human will pass gas on average 11 times a day. So 24hours /11= 2.8 and then 2.8 times 3 = 8.4., 8.4 times an hour for every 8 hours worked the air in the restroom will need the fan to remove the odear from the restroom. Now excatly how much each one of the human bodies releases and how ,ong the fan will need to run ot the amount of air being move I could not say.
I just thought it was a weird fact the doctor gave the old lady when she had a stomach problem.
Register to Reply 8 comments
Anonymous Poster (3); dadw5boys (1); matthew@lioncity (1); Mr. Truman Brain (1); ozzb (1); PWSlack (1)
