Previous in Forum: Wood gas   Next in Forum: who are the blumeanys?
10 comments
Lifts Potential Energy Utilization
07/30/2008 4:38 AM
How can we tap into the potential energy of lifts to create a sustainable building environment. I believe we have a huge potential to tap the energy here by using some sort of an hydraulic system to absorb and transmit this potential energy which would be immersely available in the vertical transportation systems. Is this technology already being employed?
Pathfinder Tags: LIFTS POTENTIAL ENERGY
Re: Lifts Potential Energy Utilization
07/30/2008 4:47 AM
I would imagine this technology has always been employed...
In the form of a simple counter weight , or two lifts moving in syn'c.
Good Answers: 18
07/30/2008 8:36 AM
One could install a generator with an overrunning clutch to tap the potential energy of a lift returning to a lower level due to gravity and store the energy in a bank of batteries.
Of course, each system would require some engineering work to insure that the generator load matches the lift weight and speed to take advantage of the peak energy transfer without slowing the lift to the point that it begins to cause a loss of productivity.
07/30/2008 2:59 PM
its already being done.
Good Answers: 54
07/31/2008 12:40 AM
Most variable speed drives (of the size needed to drive a lift system) brake by acting as an alternator and dump the recovered energy back into the power grid.
I've heard that old electric railways would have one engine going down a hill at the same time another was going up, that way the generated power from the first would help provide power for the second.
Of course it meant all the trains had to run exactly on time.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
07/31/2008 3:33 AM
London Underground, among other metro rail system operators, employs regenerative braking.
07/31/2008 5:10 AM
Not to mention the old Victorian system of energy recovery in some underground stations with no moving parts and 100% reliability...!
But how!
It's impossible!
Oh yes...the track runs up hill into the station, the line then slopes down allowing the train to coast away from a stop.
Damn reliable gravity....
07/31/2008 10:21 AM
But does the regenerated power go back to the rail or is it disapated as heat like it is on a diesel electric train?
Travis
07/31/2008 12:31 PM
It's used to power a HUGE audio system that makes that scary noise, and the rushing wind when they sweep into a station .
07/31/2008 2:25 AM
All of the lifts I am familiar with (Elevators to the Yanks) use a counter weight to keep the motor size needed to lift them and their loads to a reasonable size. Hence, no great store of potential energy. Sorry, good thought though.
Good Answers: 183
08/23/2008 8:29 AM
For movements on teh vertical the problem is different. In order to avoid any load fall in case of motor or power supply failure the system is self locking. Thus the motor has to be used in both directions. This for mechanical drives. The cabin brakes are for a cable failure.
Hydraulic elevators can be used with a part of energy recovery using the down stroke to load an accumulator used for the up stroke for instance.
Register to Reply 10 comments
Anonymous Poster (2); Bill (1); ffej (1); nick name (1); PWSlack (1); user-deleted-1105 (3); vicini (1)
You might be interested in: Lifts, Vehicle Lifts, Scissor Lifts
