Friends,
I am working on a project- high temperature fluidised bed reactor.
Briefly, it is a pilot unit comprising- Gas metering/mixing (LPG, CO, Ar, N2, Air),
Pre heater, Alumina tube Reactor (5" diaX39"length),three zone furnace ( each zone 9" ) using MoSi2 elements.
The top and bottom ends of the reactor are cemented into SS304 flanged tubes.
The top end is water cooled.
Electrical control is using PLC's (AB) and Phase angle control for power, to ramp up
the temperatures to 1500C.
Now the PROBLEM:
After leak sealing upto 10 psi- the system is not pressurised- we heated the
reactor upto 1350C. Ramped up to 600C at 5C/min, upto 1000c at 4C/min and
at 3C/min thereafter. Upon overnight cooling (unramped), we found the reactor
tube cracked at about 2" below the top cold junction , next morning. The length
of the tube from top hot zone to cold jn. is 8". Can somebody with experience
in such work, comment on this and suggest changes for future safety. These tubes
are very expensive.
We are taking steps to prevent heat leakage upwards from last zone, and also
increasing the length of the tube top section for a more reasonable temp. gradient.
Suggestions will be most welcome.
fsmonder
